Old 11-14-2013, 09:17 PM   #1
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
Solar panel on Air Conditioner??
Have had 92 Excella for month now and was up cleaning and inspecting roof and there is a solar panel on the air conditioner. I don't see switch or anything - does this automatically transfer some kind of charge to batteries however minimal that may be. Confused - thanks
pt1949 is offline   Reply With Quote
Old 11-14-2013, 10:06 PM   #2
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
I have a 1991 Limited with the factory solar panel that I assume was intended to be a trickle charger to maintain the batteries in storage (see picture below). There is no switch and it only feeds unregulated voltage to the batteries through a diode. The problem that I've had is that they overcharge the batteries and have caused the electrolyte to dry up. I plan to do a thread on this system some day.
Steve
Steve Bryant is offline   Reply With Quote
Old 11-15-2013, 10:30 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
There are many places to get info on solar operation.
Below is just one of the better to explain FAQ.
BatteryStuff Articles | Everything You Need to Know About Solar Chargers
Your location is a large influence on how large your system should be to do the job required.
Any solar panel should have a fuse that can be removed to disable it, to allow maintenance on it and other systems.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 11-15-2013, 07:45 PM   #4
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
Thanks I will look it up and see what it does and go from there. Thanks again
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Air Conditioner Bettye Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-08-2011 01:10 PM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
