11-11-2016, 07:27 AM
2007 28' International CCD
1999 34' Limited
2009 22' Interstate
Woodbury
Solar
How much would it cost to have a 160 watt solar panel installed. Do I buy just the panel or do I need other pieces of equipment to make it work?
11-11-2016, 09:01 AM
Charleston
, South Carolina
contact outsidesupply.com. i added 2 more gopower panels to my AI, and now i have 300 watts.
11-11-2016, 09:08 AM
Saint CHarles
, Missouri
Solar Panel install
When you add a solar panel and you don't already have a solar system installed, you will probably need a charger in between your panel and battery. Some portable solar panel kits will have the charger as part of the kit.
11-11-2016, 10:24 AM
1999 34' Limited
2009 22' Interstate
Woodbury
The unit I bought says that it is wired for solar.
11-11-2016, 10:40 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
That just means that there is an inadequately sized wire from somewhere on the roof to someplace inside the trailer where a solar controller would go.
To get good answers to your question, check out the AM Solar website (link below.) They have some very good information in their DIY Instructions section. They also sell complete kits with everything you need to do a good installation. You may find less expensive sources for a DIY installation but AM Solar is geared for RV owners and sells complete kits with every part you will need. Plus their installation support cannot be beat.
http://amsolar.com/
Bob Martel
WBCCI# 5766
11-11-2016, 10:44 AM
2006 25' Safari
St. Augustine
To have solar you need a panel, a charge controller, a mounting system and compatible wiring.
It gets tricky. Solar requires direct or almost direct sun to function well so there is even a chart/map based on the latitude/longitude and number of hours the sun is in optimum position. So, you may want your mounting system to tilt as well. ALSO, not all charge controllers are compatible with all battery types. Some are or at least are programmable to be use with other types. On an on it goes just full of decisions to make! I am sure someone else will mention the wire gauge/length issue! Newer Airstreams come with pre-wiring for Solar though some say the wiring is inadequate. I used my wiring. Consider also how you will mount the panel on your roof. You do not have to drill holes. You can use super adhesive caulk stuff.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
11-11-2016, 10:59 PM
Charleston
, South Carolina
i drilled holes and used sicaflex per airstream's recommendation. i keep a compass in the van and try to park so that i get as much sun as possible. 300 watts is helpful, but 3 panels are not really enough to keep the batteries charged overnight if you are running the fridge/freezer and lights, etc, as the panels only produce while the sun is shining during peak hours. you will want to run the engine some or get plugged in. i was in halifax for canada day and decided to stay in a hotel. i left my fridge/freezer running to keep wine chilled. each morning, i needed to run the engine for a few minutes to bring the batteries up. if you park somewhere on a hot day and want to run the overhead fan, 3 panels will produce enough for that and run the fridge/freezer during peak hours.
11-12-2016, 05:26 AM
1984 27' Airstream 270
Scotia
, New York
http://theouterlimits.ws/projects/airstream/solar/
400 watts in my setup, it was starting from scratch and winging the install. The panels are only a fraction of the cost. Running the wires can be your biggest challenge.
11-12-2016, 02:42 PM
2016 30' Classic
Houston
I suggest that you direct your question to site participant Lewster, a professional RV technician, solar expert and a willing advisor to many on this site. I just had a 900W / 600 AH lithium system and really look forward to the additional capabilities it will give us on the road. Good luck. Dennis
