Old 07-08-2019, 12:34 PM   #1
Sofa To Bed Platform Wonít Fully Extend
I have a 2015 FC 25 FB. The sofa couch should extend to make a full size bed but one of the slide mechanisms only comes out a few inches, then gets stuck. It feels like something may be blocking the track. Hard to see though. The platform doesnít have any screws to remove it so that I can access the slide. I called the factory and was told the platform is constructed as a box and stapled together. Has anyone had this problem, and if so how did you get to the slide mechanism? Thank you in advance.
jonnie3 is offline   Reply With Quote
Old 07-08-2019, 09:01 PM   #2
some town , PA
We are actually having the Same problem now! I was able to climb under there and it looks like a screw thatís holds the mechanism has come out a little blocking the track. I am still trying to figure out how to get to it. I will update this if we figure it out
philly_air is offline   Reply With Quote
Old 07-08-2019, 10:58 PM   #3
Thanks for the reply. I talked to the factory, as well as two other Airstream service departments, but nobody seems to have an answer. If I come up with a solution I'll let you know.
Couch-To-Bed Platform Wonít Fully Extend jonnie3 General Interior Topics 0 07-04-2019 10:45 AM
2016 Interstate- Power Awning won't open-extend Haasman Sprinter and B-van Forum 2 08-03-2016 01:22 PM
Stairs extend and won't retract israndy Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 02-22-2016 11:04 AM
1972 Ambassador - main step won't fully extend flaagan Steps 15 03-02-2015 11:41 AM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-18-2010 11:57 PM
