We have a hinged 6 foot door under the sofa which hides three storage bins. The plastic connectors at each end have broken. Tried hook/eyes which got tangled and had to break to get it open. Then tried magnets - too weak. Am looking into Neodymium magnets with 10 lb pull force 7/8" round yet I worry that the door will not support the pull force to open and close without the screws flying out! I'm guessing the fabric covered door board is 1/2 inch plywood. Any thoughts if I am heading in the right direction or any other suggestions (husband out-of-town!!) THANKS IN ADVANCE! Lynn
What about the cabinet child safety magnet lock? It is a basic latch that is held into place until a magnet releases it from the outside. It is a bit of an inconvenience, but for $10 it would hold it shut no problem and then have little to no force needed to open it. (just don't loose your magnet)
These 'grabber latches' are used to hold the doors closed on newer trailers. They are available from out of doors mart for $6.95. I just ordered one yesterday.
Hi, when I remodeled my living room, I recovered my gaucho and the door; My door was more like 1/8" and it broke, but still looks good and still works. Your's being older might have a thicker board, but I doubt it.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Thank you for your suggestions. I did try Velcro also but with whatever heat it would not stick against the fabric backing. I will look into the Grabber Latches - just seems like more plastic to break eventually. I appreciate all of your input!
