Old 08-30-2014, 09:30 PM   #1
jvcolaizzi's Avatar
2016 30' Classic
Park City, Utah , Utah
Angry smell from somewhere dirty
the proper technique is always used when draining my black & gray water tanks. i also use a flush king frequently after draining. i also use chemicals in my tanks as suggested. Regardless of all this i still always smell stink. I even smell stink around the outside of my trailer. Can I be doing something wrong? Or do I have a broken something?
John:
jvcolaizzi is offline   Reply With Quote
Old 08-31-2014, 02:05 AM   #2
2005 19' Safari
GLENDALE , AZ
If you are in La Quinta, your weather is similar to Phoenix.
We have tried about every kind of deodorant, including "The Geo Method", "green" chemicals and various marine toilet products. However, Thetford Campa Chem with formaldehyde (the blue stuff) is the only thing that seems to work in extreme desert heat. In cooler weather, most of the other products provide satisfactory results; but in the summer, that's all we use.
Campa Chem Liquid Holding Tank Deodorant, 64-ounce: Other Patio & Garden : Walmart.com
Depending on the size of your holding tank, 4 ounces will usually work in cooler months. However, in 110 degree heat, the standard dose of toilet chemicals is usually insufficient to control odors. So, during the summer, I'd double that to 8 ounces (1 cup). Then, as your tank fills, if bad odors return and you are unable to dump, add another 8 ounces.
Note: This is the same stuff that the airlines, trains and buses use in their toilets. And, despite what most people think, this formula is biodegradable. Also, be careful handling this chemical; as it permanently stains anything it touches blue (except the toilet), including walls, floors, and your hands!
Good luck!
It's a dirty job, but some one has to do it! thecatsandi Waste Systems, Tanks & Totes 20 10-02-2006 01:09 PM
Help....Quick and Dirty Melody Ranch 1961 - 1963 Bambi 6 04-19-2006 12:35 AM
Airstream, my dirty little secret. krowsea Our Community 1 09-07-2004 03:06 AM
Dirty water system Michael W Waste Systems, Tanks & Totes 13 05-06-2004 04:12 PM
Tell me your dirty laundry... Safari Tim On The Road... 48 03-17-2004 02:32 PM
