Hi Anders79. Welcome to Air Forums. All Airstreamers are constantly vigilant for leaks. You'll get good at finding them.
As you know there is 1 1/2 inches between the outer skin and inner skin. What might be migrating into the interior on the inner skin may not be close to where the leak is.
Study the outside of your trailer closely. Marker lights, roof penetrations, skin seams, rivets and window frame joints are all suspects.
I take my garden hose with spray nozzle set to shower. I clamp it to my step ladder. I start low and I work my way up the area where you discovered the leak. Sometimes it takes 30 minutes before the leak will appear. I found one at my rear window, and I found one at my rear end cap seam using this garden hose method.
A better way is the "seal tec" method where you pressurize your trailer with a high volume fan and then soap the seams. This is a more positive method. Some RV dealers can do this test for you. Getting your trailer leak free is worth the money.
There are several sealant threads on Air Forums. I like the Acryl R that Airstream uses for seams and joints. Tempro 635 is a good caulk for vents and the like. Silicone caulks are not welcome on Airstreams.
And buy a moisture detector. Every three months or so get on your hands and knees and probe the intersection of your interior wall to the floor. The moisture detector will find wet spots you did not notice. It's the best way to keep your new trailer dry and long lasting. Moisture is a killer for Airstreams like most other things.
David
