Old 08-10-2015, 08:59 AM   #1
Small amount of water under door mat top of mat dry 2015 sport 16
Two times this month parks in drive way Tampa area..
big2win is offline   Reply With Quote
Old 08-10-2015, 09:18 AM   #2
mandolindave's Avatar
Condensation remove mat see if dry
mandolindave is offline   Reply With Quote
Old 08-10-2015, 09:29 AM   #3
also.....
Door common leak spot does mat let water seep thru dry on top
Old 08-10-2015, 09:41 AM   #4
The Mat is only wet between floor and bottom of mat top of mat bone dry
Old 08-10-2015, 09:52 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Check for water leak running along the wall toward the door.
Old 08-10-2015, 01:24 PM   #6
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Do not let moisture remain under the door mat. I have a new black mark on the floor from this same problem, and it happened fast. I'd post a picture but photos are not working on this site currently
Hiho Silver is offline   Reply With Quote
Old 08-16-2015, 06:44 PM   #7
Found out where water is coming from.. It's from the refrigerator vents.
Hard blowing rain.. How do I stop this, any ideas thanks everyone for help..😀
Old 08-16-2015, 10:06 PM   #8
1979 23' Safari
Wayland , New York
If it's not I use at the time and the fridge is not running tape some plastic inside the vent door, remove before use.
Is there screen on the inside of the vent doors? If not rivet some aluminum window screen to the inside, ant water that gets past the louvers should hit the screen and run down and then out. Small gap in the gasket bottom behind the hinge should allow a drain path with hinge blocking inlet of water. Look at it, I'm not sure how newer doors are set up.
Old 08-17-2015, 05:50 AM   #9
Ok I will give t a try.. Thank you for your help.,.
Old 09-03-2018, 09:28 AM   #10
2017 28' Flying Cloud
Milton , Florida
Have you found a way to remove the black stain?
MonkBurns is offline   Reply With Quote
Old 09-03-2018, 09:46 AM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I agree -condensation. Had it mine, changed to a more breathable door mat- problem solved.
2019 Ford Expedition Platinum
Old 09-03-2018, 09:50 AM   #12
Sorry I did not. I was told it was from a “black coating?” Which Airstream puts on before the floor. So my black stain was from a rubber mat being wet on the bottom from a leak, and the stain welled up from under the floor. That was over 3 years ago, and I no longer have that trailer. Good luck!!
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Teak Bath Mat 2011 Bambi Sport Airbambi16 General Interior Topics 0 10-17-2013 12:13 PM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Snow and a fair amount of it.... Silvertwinkie Our Community 3 03-04-2003 11:12 AM
