Old 06-05-2015, 11:37 AM   #1
1986 25' Sovereign
Cincinnati , Ohio
Sliding door to center bathroom stuck
We have a 25' '86 sovereign with center bath. The bathroom sliding door is stuck in the open position, allowing us to get into the bathroom. We can not close bathroom sliding door. It seems to be immobile. We were scraping off shower wall paper for painting purposes and my wife removed the sliding door support screws in the shower wall so she could get at the wallpaper. We reattached the screws but no luck on the sliding door. What did we do and how do we correct it?
Thanks in advance
Steve
Ssmookler is offline   Reply With Quote
Old 06-06-2015, 07:04 AM   #2
Missouri Valley , Iowa
Steve,
Did you try removing the screws that you previously removed from the bathroom wall? Maybe one of them went back in the wrong place. If you can slide the door to the closed position and then remove it from the hangers you can take a light and shine it into the area where the door was. Reinstall the screws and see if they are somehow interfering with door movement. Removing the door on my '02 Classic only required a twist of the plastic locking mechanisms on the door top hanger when the door was in closed position.
Dan
Farmer Dan is offline   Reply With Quote
Old 06-06-2015, 08:16 AM   #3
1986 25' Sovereign
Cincinnati , Ohio
Bathroom sliding door wont close
Dan
Thanks for the suggestion. Will remove screws and try again Our problem is that we can't close the door. The door seems locked in the open (we casnget in the center bathroom) but we can't seem to get it closed. I thought I could avoid taking the door off the support track.
Steve
Old 06-06-2015, 12:29 PM   #4
1986 25' Sovereign
Cincinnati , Ohio
Dan
Removed the screws and it turned out that the sliding door was locked when we retightened the screws. The far right screw locked the sliding door in and served to keep it immobile. I unscrewed the screws and the sliding door was freed to move again. Simple solution. I again, am feeling humble.....
Steve
Old 06-07-2015, 11:15 AM   #5
Society Hill , South Carolina
Hey Steve, Airstreams make us all feel humble once in a while. Glad you got your problem solved.
Martin1214 is offline   Reply With Quote
Old 06-07-2015, 04:13 PM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by Ssmookler View Post
Dan
Steve
Since I have that same year and model, I will park this in the back of my mind for future use.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 08:19 PM
Stuck Sliding Bathroom Door SteveH General Repair Forum 9 03-24-2008 03:05 PM
Sliding Bathroom Door "clips"? Curtis-79MH Classic Motorhomes 1 06-26-2006 10:05 AM
Sliding bathroom door hardware steelbird312 1987 - 1989 Excella 2 12-13-2004 01:13 PM
