Old 04-08-2016, 04:57 PM   #1
S/OS #005
2004 28' Safari S/O
Georgetown , Ontario
Slideout paddle latch not working
One of the paddles is not operating, the other works fine.
We spent tuesday night at jackson centre, everything working fine but wed night down the road, the paddle doesn't have power. Any ideas?
JACQUIE is offline   Reply With Quote
Old 04-08-2016, 07:18 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
You can access the appropriate motor by removing its cover in the slide-out. The controller is located under the street side couch arm just below the actuator buttons. Test for power at each location.
You may have a loose wire or the controller has failed.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-08-2016, 08:15 PM   #3
S/OS #005
2004 28' Safari S/O
Thanks, we will check that tomorrow when we arrive at our destination.
Old 04-13-2016, 06:21 PM   #4
S/OS #005
2004 28' Safari S/O
Found the problem. A disconnected wire on the locking arm motor. An easy fix. Thanks for your help.
Illinois Fall Paddle Party TinLoaf Forum Rallies & Meet Ups 72 10-19-2015 03:43 PM
Paddle Rally in the Fall Lynn S. The Rally Zone 7 10-14-2015 01:36 PM
Anyone with paddle latch rebuilds? napfeiff1 Doors & Locks 7 04-08-2014 04:33 AM
SUP? Stand Up Paddle Boards John&Vicki Airstream Lifestyle 18 03-13-2014 05:13 AM
Ohio Paddle Quest 2009 & Informal Rally!! Airbiscuit Other Rallies & Events 7 06-03-2009 10:30 PM
