Old 12-27-2014, 08:17 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Skylight isn't leaking, it's condensation
A while ago I was trying to track down a leak around the plastic skylight. The original failed and was the source of enough water to rot almost the entire floor of the trailer. I replaced that, and replaced the skylight with another plastic one, which lasted a year and then failed, then a fiberglass one, single layer. I've had odd leaks over the 9 years since that was replaced and then figured out that it is condensation, and it's simply raining INSIDE the trailer. The time has come to replace this skylight with something double glazed. I want something that is transparent, maybe tinted to limit solar gain, but I want to see out. I think condensation is causing some other wet areas, nothing too bad, and I'm curious if others have had this experience and if there are any clever solutions floating around. Thanks
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 12-27-2014, 08:22 PM   #2
dznf0g's Avatar
Oswego , Illinois
Dehumidifier in cool weather.
-Rich-
Old 12-27-2014, 08:40 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
MAXIM Skylights.. de-humidifier can help too... but on our Maxim's.. we haven't seen any serious (dripping) condensation..
http://maximskylights.com
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-27-2014, 11:38 PM   #4
Globie64's Avatar
Images: 18
Thanks- I'm thinking the Maxim will be a project this year. I've used de-humidifiers in the house in the past, but there is no power where the trailer is parked. I've used the chemical dehumidifiers but not sure if they really do anything.
Old 12-28-2014, 05:51 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Clean kitty litter works as a chemical dehumidifier (at least, the kind that clumps when wet does). Also, if you place the pan of kitty litter directly under the skylight, any condensation that does form drips right into the litter where it's safely absorbed.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-28-2014, 08:19 AM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We have the factory installed skylights. Double glazed and have never noticed any condensation. When the need arises and it's time to replace them I will go with the Maxim version. From what I read here they seem to be the best around. But, so far all's well.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-28-2014, 08:39 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We were camped in heavy rain, very cool weather this fall thinking there was a leak at the rear corner of the Airstream next to the corner nightstand, but instead found water condensing on the lower wall and making its way down into the floor. There was little to no air circulation in that area.
Ventilation is difficult in these conditions because it's humid inside and out. Good to ensure your heated air is reaching the corners of the trailer, not blocked by things stored along the wall.
Doug and Cheryl
Old 12-28-2014, 08:58 PM   #8
Globie64's Avatar
Images: 18
Yup, it was very rainy and temps were cool. Air circulation will help, the cat litter is a brilliant idea and I'm curious to see if I can find a small 12v fan and combine it with PV panels. It's really cool and damp where we are, on the Pacific coast. Between the Airstream and our old Alfa Romeo, it's never a dull moment.
Old 12-29-2014, 04:57 AM   #9
Take your cue from boat owners and install Nicro solar vents from Marinco. Available in both 3" and 4" diameters, these "mushroom" vents might be just the ticket. Especially if you install two, one at each end, and set one to blow and the other to suck. The stainless steel model would be very discrete on top of your Airstream. And they're rainproof!
4 inch Stainless Steel Day/Night Plus Vent | Marinco
If/when my bathroom vent gives out, I'm giving serious consideration to installing a Nicro to replace the existing vent.
WBCCI #1105
TAC LA-4
Old 12-29-2014, 05:50 AM   #10
Gainesville , Florida
Go to any truck stop accessory store to find more twelve volt appliances including fans. Jim
Old 12-29-2014, 07:06 AM   #11
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
MAXIM skylights are the only way to go. When you see the difference in the quality of these skylights you will be amazed and know that you have the best.
My factory installed skylights were cracked by over tightening of several hold down screws. I went to the trouble of exactly measuring them then calling MAXIM, however the knowledgeable staff only needed the year and length of my AS to match the exact size of my skylights from their records. My new lights arrived on time. I unscrewed my old skylights, ripped them off in pieces, stuck my legs down the open hole, then comfortably scraped the caulk away which was a chore. You will need several tubes of caulk and some stainless steel sheet metal screws and a battery drill. Once the new MAXIM skylights are installed, if you still have a leak problem, you can be assured the leak is not from your skylights. MAXIM offers smoked, milk and clear Lexan and white, black or silver metal frames. They are built with a dome within a dome (2 layers with dead air space between) and a flat panel on the bottom. Total of 3 layers of Lexan. I full time in my AS in all kinds of weather and have never had a sweating issue with the MAXIM skylights except for a small band of the metal frame that rarely gets little beads of water on it. Opening a window and fantastic fan vent about 1/2 inch each keeps the air moving and reduces moisture build-up until the sun comes out. Spend the extra money it takes to get MAXIM skylights!
NOAZRK2690 is offline   Reply With Quote
Old 12-29-2014, 07:23 AM   #12
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Great suggestion, Protagonist! Multiple uses, cheap to operate! I use the same exact fan to circulate the air from the coils on the frig. Improved the efficiency, WOW. The dehumidifier will remove the humidity in warm moist environments. As per other threads on condensation, if your door is open when you operation your A?C, your apped to cause dripping from your ceiling unit because of moisture from the outside. Didn't mean to highjack this thread but I thought these were important points.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 12-29-2014, 01:23 PM   #13
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Excess moisture from condensation was one of the main reasons for the headliner failure of the 90's trailers. The water-based glue in use at the time just failed miserably.
I keep an eye on my glass window panes in the winter: if there is condensation on the windows then I know I need to ventilate more.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-30-2014, 09:00 PM   #14
Globie64's Avatar
Images: 18
I actually installed a Nicro fan in 2011, and it worked really well for 18 months, slowing until it pretty much failed. It was great, chugging along day and night, and it helped with the condensation but not entirely. I had installed it to air out the trailer for that it was great, but I wasn't in too much of a hurry to replace it, at $175 bucks a pop. Apparently this has become a common problem with Nicro fans made in the last few years, with production switched to China. Then I went to look at marine forums to see if I could find battery replacement information.. none yet but apparently the battery is now replaceable- apparently they hadn't been. I also didn't pay attention to the 2 year warranty. I tend to buy marine stuff for the Airstream when the quality is better than RV products, and may try to replace the battery or just buy a new unit. I don't like the way it looks- I mounted it to the old metal bathroom roof vent, figuring I'd replace that with a Fantastic fan.
AC condensation drain leaking inside window frame, running down screen Aggie90 General Repair Forum 0 04-11-2014 07:25 PM
Leaking Skylight Brow324 Roof Vents, Skylights & Fans 13 06-10-2012 02:24 PM
'61 tradewind leaking skylight shiney61 Roof Vents, Skylights & Fans 2 07-25-2010 10:06 AM
2005 Int'l leaking around skylight jsprad Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 02-03-2008 10:11 PM
