Old 04-19-2019, 09:03 PM   #1
2019 26' Flying Cloud
Jacksonville , North Carolina
Skylight Frame dropping
New 2019 FC and noted that one side of the interior skylight frame has dropped down about an inch. Tried pushing back up but will not stay in place. No screws or detents that I can see holding the rest of the frame in place. Any idea on how it should be held in place or remedies? No leakage in the inside and no visual damage to the exterior top.
stevejant is offline   Reply With Quote
Old 07-16-2019, 04:45 PM   #2
Longview , Texas
Hi Steve. I am having the exact same issue. Mine is a 2015 FC. Were you able to find a solution?
Aggie90 is offline   Reply With Quote
Old 07-17-2019, 06:59 AM   #3
Temp Skylight Frame Solution
Short term solutions included silver duct tape and then Command Velcro adhesive/tabs all of which eventually failed. What is working now (until I can get to a AS facility) is I removed the two screws on the side that was dropping and replaced them with longer self taping screws. I initially tried 1/4 longer screws and when they did not hold I went to 1/2 longer screws and that appears to be working after two road trips.
Maxim Skylight Interior Frame Condensation KJRitchie Roof Vents, Skylights & Fans 1 06-17-2017 06:51 AM
skylight gasket, velcro residue on skylight glass basecamper Base Camp 0 06-11-2016 09:52 AM
Connection dropping? ALANSD Off Topic Forum 7 04-03-2004 03:47 PM
Dropping the fresh water tank... drboyd Fresh Water Systems 12 11-04-2003 09:37 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
