Old 09-26-2014, 04:11 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Sitting on a slope
We are parked on a sandy slope (sort of) its solid enough but not level, so I bought some jack stands and needed one of them for one side. I figure near the tires. I can't figure out the place to put it under thats correct where any sort of jack would go. Got any tips? axle?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 09-26-2014, 04:14 PM   #2
dznf0g's Avatar
Oswego , Illinois
NOT AXLE.....I use jack stands on the axle plate only for storage. Four of them...just aft of the rear axle and just in front of the front axle.
-Rich-
Old 09-26-2014, 04:19 PM   #3
1970 27' Overlander
If the axle plate is the vertical metal (thats thick) and behind the tires, that is what I have decided to set one jack stand. I know not to use the levelers for jacking. Just thought there was a certain 'place' that a jack should be set under there.
Old 09-26-2014, 04:22 PM   #4
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Sitting on a slope
The axle plate is the heavy vertical steel that the axle is bolted to. My 74 Sov was on four jack stands on the axle plates for over a year while I worked on her... Even after I had removed the axles.
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 09-26-2014, 04:27 PM   #5
1970 27' Overlander
I just want to make sure we are all talking about the same thing. Because the vertical steel wall is all I see when looking underneath there...so that is what I am going to set one jack stand under...I just need about a four inch lift and am tired of a fridge door that swings open. lol.
Old 09-26-2014, 04:31 PM   #6
Panama Red's Avatar
Obrien , Florida
There is a very heavy vertical metal plate that each axle, and the shock absorber, is bolted to. That is what I'm talking about as the axle plate. I had my trailer supported solely on jack stands under those plates for quite a while.
That's the ONLY place I would place a jack for lifting, or a jackstand for support, on my trailer. I have a thread, Resurrecting Big Bertha, that has quite a few pictures of my trailer with the axles removed... I'll see if I can find one of the Jack stands on the axles plates.
-Red
Old 09-26-2014, 04:33 PM   #7
Panama Red's Avatar
Obrien , Florida
Best, and easiest, way to level on a slope is with the drive on Lego blocks...
-Red
Old 09-26-2014, 04:34 PM   #8
Panama Red's Avatar
Obrien , Florida
Sitting on a slope
And, as previously stated, DO NOT Jack the trailer up, or place a Jack stand, on the axle tube. The bend of the tube sets up your wheel alignment. You really don't want to change that...
-Red
Old 09-26-2014, 04:41 PM   #9
1970 27' Overlander
We have been parked here for about four months...not realizing the kitchen side was settling -I usually would just take a two X four and back the tires up on it, but not this time. So I got a set of three ton jack stands and am going to use the one for the purpose of raising it a few inches (with a bottle jack first) then set the jack stand in place. Red I am sitting here if you find that link with photos.
Last year a fellow showed me how to replace the rings in the wheels which I did myself and him coaching...but we were using a floor jack on a pcked gravel parking surface and I just could not remember where we had it set.
Old 09-26-2014, 04:46 PM   #10
Panama Red's Avatar
Obrien , Florida
Go to my thread, "Resurrecting Big Bertha... or, How I Spent $30,000 On A $2,000 Trailer" and look at post number 171. The first picture in that post is a picture of the axle plate. Anywhere on that plate should be good. Still looking for a picture of the jack stands.
-Red
Old 09-26-2014, 04:47 PM   #11
Panama Red's Avatar
Obrien , Florida
About four or five pictures down you'll see a picture of the new axle installed with a jackstand right beside it...
-Red
Old 09-26-2014, 04:52 PM   #12
1970 27' Overlander
See if you can stick a link in here Red ---- ok nevermind I found it. Hey thanks, it always helps to get advice from you guys.
Old 09-26-2014, 07:06 PM   #13
Panama Red's Avatar
Obrien , Florida
Hope it helped... Sorry I couldn't stick the link in. I was headed out the door while posting...
-Red
Old 09-27-2014, 08:36 AM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Maybe I'm missing something here - I carry several 2"x6" boards about 2 feet long that have one edge beveled. I use these to level from side-to-side by placing them just in front of the lower side's wheels and drive up on them. The front-to-back level is via the tongue jack, and then I lower the stabilizers. So, why the need for jack stands?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
hitching up on slope wasafari Hitches, Couplers & Balls 4 06-11-2007 09:10 AM
slope pad for black holding tank Silverslug Waste Systems, Tanks & Totes 6 06-07-2006 10:40 PM
Slope Pad Silverslug 1974 - 1979 Sovereign 0 06-07-2006 08:49 PM
Does it hurt to leave A/S parked on slope rixan General Motorhome Topics 4 09-11-2004 07:37 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
