Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-07-2015, 11:41 AM   #1
1989 34' Excella
Sink Cover Questions
Rank noob alert - just bought my first Airstream, an '89 Excella, and am preparing/outfitting it for full-time use.
Regarding the heavy cover plates that fit in the kitchen sink ... D-shaped with a finger-hole, appear to be made of the same material as the countertop:
1) Can these be used as cutting boards?
2) What material are they made of? (Just curious.)
3) A thorough washing has revealed a couple dirt-trapping chips in each. Can these be sanded out or filled? (Important if it IS intended to be a cutting board)
4) Is there a functional reason why they're so darn heavy?!? (To keep them from bouncing around in transit or something?)
Thanks in advance --
MohawkDaddy is offline   Reply With Quote
Old 07-07-2015, 12:19 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The sink cover in my Bambi II was made of laminated plywood. Never tried to use as a cutting board, just soft wood. The cover on my Safari is made from heavy duty plastic/polyurethane. I use it as a cutting board regularly.
MICHAEL
Old 07-07-2015, 09:20 PM   #3
1979 23' Safari
Wayland , New York
Generally they're heavy due to thickness and particle board, they're same as countertop. So would you use that as cutting board , you can but expect them to get cut up, also not made to be easily sanitized/washed.
They're meant to provide extra counter space when not using the sink.
Do not leave them in the sink during travel, they have a very high tendency to become projectiles that cause damage.
Old 07-08-2015, 06:02 AM   #4
1989 34' Excella
That helps, thanks.
I WON'T use the inserts as cutting boards then, and will buy a dedicated cutting board for my chopping and slicing needs. At some point, I may replace one or both inserts with cutting boards, though, which would be a fun project and look pretty.
Old 07-08-2015, 06:14 AM   #5
dznf0g's Avatar
Oswego , Illinois
Mine are Corian and would cut easily if used as a cutting board.
-Rich-
Old 07-08-2015, 06:16 AM   #6
1955 22' Safari
Laredo , Texas
My Solution
The one in my Bambi II was chipped, ugly and HEAVY. Replaced it with a cutting board mounted to plywood and added a finger hole.
55AS is offline   Reply With Quote
Old 07-09-2015, 04:55 AM   #7
1989 34' Excella
Cool!
Old 07-09-2015, 05:30 AM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Take it a step further.
2019 Ford Expedition Platinum
Old 07-13-2015, 08:46 AM   #9
1988 32' Argosy
Dallas , Texas
Related to this: do you guys know of a good supplier for sink cover replacements? I have an '89 Squargosy with no sink covers and would love them so I can have more counter space. Thank you for any info!
ETxArgosy is offline   Reply With Quote
Sink Cover daparham2 Sinks, Showers & Toilets 2 06-27-2014 10:02 AM
circular sink cover jim1949 Cabinets, Counter Tops & Furnishings 1 06-10-2014 01:51 PM
1975 Sink Cover Bassistross General Repair Forum 2 03-17-2014 07:44 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
