Old 04-12-2017, 01:27 PM   #1
1972 31' Sovereign
Carbondale , Illinois
simple 72 sovereign thing
Where is the battery kill switch in a 72 sovereign.
solo pilot is offline   Reply With Quote
Old 04-12-2017, 03:41 PM   #2
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
doubt it came with one
cliffcharb is offline   Reply With Quote
Old 04-12-2017, 03:57 PM   #3
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Doesn't have one.
You can easily install one. Best is on battery terminal type.
Silver Hawk is offline   Reply With Quote
Old 04-12-2017, 05:31 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It's located on the negative battery terminal itself, and usually requires a 1/2" wrench to actuate by removing the terminal end.
Old 04-12-2017, 05:49 PM   #5
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
It has a plug
on my 72 sovereign there is actually a plug built into the battery cable, it looked like a molded section roughly centered between the two ends. it should be accessible from the battery box door outside. I removed the cable to replace them with new ones and then I found out it came apart. it looks like a very large 2 pin 12 volt connector. the connector was corroded enough that at low current, it wouldn't connect. I replaced them with new 4 ga cables, and just unhooked the batter at the terminal.
"Daddy when's the trailer going to be finished?"
Can of beans is offline   Reply With Quote
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 04:23 PM
1986 Airstream Sovereign 31'' ever thing works click n bid hurry eBay Watch Airstreams on eBay 0 11-30-2011 08:50 PM
The Simple Life...simply stupid! yukionna Off Topic Forum 56 08-05-2004 01:19 PM
"Simple Life" - Initial episode jordandvm Our Community 6 06-09-2004 02:31 AM
Super Simple Polish Method Safari Tim Cleaning, Stripping & Polishing 8 08-08-2003 09:17 AM
