Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-08-2012, 12:29 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Silicon removal..
Has anyone found a solvent/method that safely removes cured silicone?
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 04-08-2012, 12:42 PM   #2
mapleton , Utah
silicone removal products can usually be found at most any Home Depot, Lowes etc. VTS also has a very good product available. It helps to do it on a warm day (or you can use a heat gun to speed things along)
tim
rumrunner is offline   Reply With Quote
Old 04-13-2012, 07:07 PM   #3
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
We've had the best luck with McKanica, it's the product Vintage Trailer Supply sells.
~Lynnetta
Someday'59 is offline   Reply With Quote
Old 04-14-2012, 12:50 PM   #4
Wabbiteer's Avatar
Jupiter , Florida
Just a factoid to keep in mind:
Dow-Corning flatly states cured Silicone caulks/adhesives have 'no known solvent' so what the 'removal' products do is break the bond with hard surfaces silicone has slimed, err... the silicone has been applied to.
I just recycled 3/8" plate glass shelves that each had six feet of silicone residue from glued-on oak trim... only took 60 minutes each using a fresh razor blade and shaving the three sides at the glass edges down to bright shiny glass, so if you're getting more than one foot per ten minutes with a removal-product it sounds like a deal...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 04-14-2012, 02:47 PM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
we've had some success using a "3M Stripe Off Wheel" to remove what's left after cutting off closely with a knife - Stripe Off Wheels:*Stripe Off Wheels
you can commonly find them on Amazon - Amazon.com: 3M Stripe Off Wheel 07498, 4 in x 5/8 in, w/Hardware - 7498AM: Home Improvement
you need a power tool that you can hold steady, as the wheel will "run off" if you don't hold tight!
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
jm2 is offline   Reply With Quote
