Old 01-28-2014, 09:30 PM   #1
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
Side battery door on a '71 Overlander and rear twins.
So I'm wondering if someone can take a look at the photo of the curb side of my 1971 Overlander and let me know if the battery door is factory or a PO mod. Most photos have the slide out battery box. This one had the battery in the rear and the side access is a regular small hatch door. The odd thing is that the curb side aluminum bunk rail mounted to the side covers about a third of the opening. There is a nice piece of vinyl coated aluminum covering the part of the opening that sticks above the bed channel. Seems odd and since I'm redoing the rear bunks should I raise the beds to allow the full use of this hatch? What is the bed height supposed to be? Thank for any tips or insight!
chilipepper is offline   Reply With Quote
Old 01-28-2014, 10:11 PM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I would guess the door is factory, however not for the battery. The battery compartment should be sealed from the interior of the camper. The door you are asking about looks to be outside access for storage under the bunk. Like for a jack or wheel blocks.
As for the bed height, I would think it should be whatever you are comfortable with. i.e. space between the bottom and top bunk as well as the top bunk and the wall cabinet.
In my 1971 Argosy the top bunk folds down to become the back of the lounge. So when I made a new base for mine, I had to keep it the same height.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is online now   Reply With Quote
Old 01-29-2014, 12:19 AM   #3
1970 27' Overlander
Gun Barrel City , Texas
That looks identical to my setup...an access door partially blocked by a low bed frame, ducting, and univolt. As far as where the battery goes, I've heard the same that it is in the rear compartment but I can't see any place to put it...with all the plumbing and back side of the molded rear bath. Personally, I think the current bed setup is too low and plan to build it up about 5 inches or more. There is a series produced by the DIY Network on YouTube about the renovation of a '70 Overlander...some good info and ideas.
gregtx is offline   Reply With Quote
Old 01-29-2014, 02:32 PM   #4
1971 27' Overlander
Thanks for the replies and I'm glad I'm not the only one with the above setup. I'm going to be rebuilding the twin bed frames anyway so I may do as you suggest, Greg, and move things up a bit to allow better access through that side door. Since that photo, I've replaced the Univolt and will go to AGM batteries to keep from having to vent a battery box. I'm also thinking of transitioning to flexible vents and remove those rigid vents. It would just be nice to develop some of that space that is accessible from the outside and make it work better. I don't like the fact that the door is partially blocked they way it is now.
My battery was in the back compartment on a little tray that lifted it over some of the plumbing. It worked however I just want to try and free up some of the outside hatch space.
Do you have any photos or drawings of how you plan to re-do the beds and raise them up?
I have watched most of the Classic Rides shows on DIY and they do have a lot of good ideas.
Thanks again!
Old 01-29-2014, 02:57 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I don't know if it was "new for '72" but the '72 Overlander has a funky battery compartment on the curbside near the rear, the door wrapped into the belly pan. Maybe that was a result of people being unhappy with putting the battery behind that rear service door?
— David
Old 07-05-2015, 10:55 AM   #6
AirConditioner's Avatar
Battery box elimination due to plumbing re-route??
Is it possible that the battery box (side compartment) was eliminated to facilitate the grey tank plumbing around this period?? I'm re-routing mine now and this will require the relocation of the battery (batteries-AGM subfloor).
I'm sure Andy knows this from his experiences of the earlier units.
AirConditioner is offline   Reply With Quote
Old 07-07-2015, 09:08 AM   #7
1971 27' Overlander
I'm not sure of that but it is a good question. I think the side compartment battery box doesn't extend past the outriggers. So it shouldn't interfere with the plumbing either way if your trailer has/had grey tanks installed. I added grey tanks to mine from Vintage Trailer Supply and ran all the additional plumbing down one side along the frame rails.
I also redid the electrical totally and added the AGM batteries (x3) and accessories under the curb side bed directly over the axles. We do a lot of boon-docking and this configuration gives me well over a week of conservative use and a weekend of hard use. I also added a 2500 watt inverter to run the TV/DVD, appliances, chargers, etc.
If you are boon-docking a lot like us the addition of the Trimetric battery monitor is a great investment too. Lets you constantly monitor where your batteries are at and what measures you need to take to remain a happy camper!
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
Old 07-07-2015, 09:28 AM   #8
1972 27' Overlander
Woodburn , Oregon
Funky
My 1972 overlander has his funky lil battery compartment but I'm moving 2 big AGM batteries under my bunk along with a new smart converter charger
shineybullet is offline   Reply With Quote
Old 07-07-2015, 01:53 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
My 71 GT had the battery in the same spot right next to the univolt. As most of my interior was gone on that side i do not know what originally sealed the compartment off. One of the reasons I changed the floorboard there was due to battery acid spilled and soaked into the plywood.
Rear twins to queen and back Peggy Raffer General Interior Topics 0 12-05-2012 06:33 AM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
My 1974 Sovereign with rear twins gvanman 1974 - 1979 Sovereign 18 04-03-2006 07:16 PM
Rear twins question Fogducker Our Community 10 04-04-2004 06:42 AM
