Old 11-01-2014, 08:31 AM   #1
1986 25' Sovereign
Cincinnati , Ohio
Shutting down heater/furnace
Just got my '86 sovereign and it is in my driveway,for now,with power from a landline. We are keeping the AS here for a few weeks then taking it to JC for a complete checkup. Some minor problems to address.
My question is how do I shut down the heater/furnace?
The thermostat does not have an off position and when I went in to the AS this morning while watching the flurries come down the furnace was on.
I don't want the furnace on while we have it sitting in the driveway using up the LPG. I want to keep the power on but don't know the right steps to shut it down.
Suggestions?
Ssmookler is offline   Reply With Quote
Old 11-01-2014, 09:13 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
For the interim, you could reduce the setting on the thermostat.
Your thermostat is likely different from ours, the on-off on the Duo-Therms is on the bottom right.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-01-2014, 09:24 AM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We had an '85 Excella. The thermostat was in the sleeping area. It was a rotary style with an on-off switch on the bottom. Not sure what yours is but the newer trailers are entirely different with AC / heat pumps and fan all included in their function.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-01-2014, 09:53 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you can not find an on/off switch, and one should be there, just disconnect one wire in the thermostat or pull the fuse.
Long term have Jackson install a switched thermostat.
2004 Excursion 4x4
Old 11-01-2014, 10:02 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Find the fuse going to the heater and remove it. Pull one of the wires off of the Propane solenoid in the heater so you can leave the propane pressured up.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-01-2014, 10:12 AM   #6
1986 25' Sovereign
Cincinnati , Ohio
Shutting off furnace
Thanks for the very helpful suggestions. I'll look at removing the furnace fuse and check out the thermostat again. I thought I checked out the thermostat but will look again.
Old 11-01-2014, 10:36 AM   #7
bigjohnn's Avatar
los lunas , New Mexico
mine doesNOT have a on - Off sw just push it to the lowest setting an that is OFF 1972 Safari ( #2741 )
bigjohnn is offline   Reply With Quote
Old 11-01-2014, 10:42 AM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Out '83 Excella shuts off when the thermostat is set to the lowest position.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-01-2014, 09:39 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
What shut it off?
Channing
WBCCI# 30676
Old 11-02-2014, 08:20 AM   #10
Gainesville , Florida
I thought mine had a little indent on the lever after moving the thermostat to the lowest temp. Just gently move the lever a little farther past the indent and it is off.
Old 11-02-2014, 08:29 AM   #11
HowieE's Avatar
Images: 12
This is the answer for thermostats that do not have a separate on/off switch. The switch is built into the range of the sweep of the stst.
If your heater does not turn off when the stst is lowered to the end of the range and pushed to a hard stopping point the stst may need to be checked.
Remove one wire from the stst and with an ohm meter across the 2 attachment point on the stst sweep the stst through the full range. You should lose continuity at the lowest point of the range. That is the switch.
2004 Excursion 4x4
Old 11-02-2014, 09:52 AM   #12
1981 31' Excella II
New Market , Alabama
Usually on the ones that have the thermostat from Suburban off is turning the temp all the way down. I thought mine was off the other day and I had not turned the thermostat far enough to the left for it to turn off. The thermostats that Suburban provides are really crappy.
Perry
Old 11-04-2014, 06:32 PM   #13
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The thermostat on my 1987 Excella is in the bedroom area. The manual simply said to move the setting to the lowest possible temperature. However, there is a simple fix to this which I did.
I bought a small SPST toggle switch at Radio Shack, and drilled a small hole in the side of the thermostat to mount it. I cut the power lead into the thermostat and connected the cut ends to the switch. Now I just have to flip the switch up for on and down for off without making any changes to the temperature setting. This, BTW, is what the thermostat in my previous AS (a LY motorhome) had.
Simple solution, works well and the cost was under $5.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-05-2014, 06:56 AM   #14
1981 31' Excella II
I will be finding a good digital thermostat at some point.
Perry
Arghh!! Generator shutting off 92landyacht Mechanics Corner - Engines, Transmission & More... 15 10-28-2014 08:17 AM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Awnings: are they really up/down/up/down ... Belbein On The Road... 6 06-08-2014 01:55 PM
down the road "Furnace on"? William Ales Winter Living 14 08-26-2008 05:42 PM
Door Not Shutting... doglickfarms Doors & Locks 1 04-25-2008 01:02 PM
