Old 08-23-2016, 07:06 AM   #1
2007 34' Classic S/O
Buffalo , New York
shower repair
Hello,
I have just purchases a used 2007 Airstream 34' which has a small hole in the bottom surface of the shower. Is there a substance that could be applied to the hole to repair the plastic? Thanks in advance for suggestions.
jcalleniii is offline   Reply With Quote
Old 08-23-2016, 07:49 AM   #2
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
Try Marine-Tek from a boat supply place (or Amazon). It's a white epoxy for marine use, so should work for your shower.
On an island in Vermont
sb55 is offline   Reply With Quote
Old 08-23-2016, 09:35 AM   #3
2016 23' Flying Cloud
Portland , Oregon
There's also a shower repair kit by 3M. I've used this to successfully patch golf ball-sized holes in a fiberglass shower surround.
Troy McLure is offline   Reply With Quote
Old 08-23-2016, 10:21 AM   #4
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I've done fiberglass repair on boats, Marine Tex has no structural matrix, more like bondo, automotive plastic body filler.
I have repaired a hole in a fiberglass sink/countertop with fiberglass/resin.
I layered the underside for a base, then filled in the hole from the top. This kind of repair won't punch thru, like a plastic scab.
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 08-23-2016, 03:03 PM   #5
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Do you know if the shower is plastic vs. fiberglass?
My 2013 25FB has a fiberglass shower. The sidewall was damaged when drilling into the adjoining wall to mount a solar power control panel. I repaired the small crack with a fiberglass repair kit I got at home depot. The product is "Aquatic Tub & Shower Repair Kit". This worked well, though the Aquatic version of "white" is grayer than the bright white of our shower.
I have also used this product to fill screw holes in my fiberglass Scamp when I replaced the taillight fixtures.
The Aquatic product is just an epoxy type product; it does not contain any fiberglass strands.
It looks like your hole is bigger than the one I had. How wide is it? Does it go all the way through? For a hole bigger than maybe 1/4 or 1/3 of an inch, I would want to use something more than just epoxy. Since it is on the floor, it has to be strong enough for someone to stand on.
SSquared is offline   Reply With Quote
Old 08-23-2016, 04:48 PM   #6
Buffalo , New York
shower fix
The hole appears to be a superficial hole; there is material beneath an outer covering. It is about 1/2" in diameter.
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 10:10 PM
Shower leaks behind shower surround Divemaster10 Sinks, Showers & Toilets 5 01-06-2015 12:19 PM
Hand shower post in shower. Jeepers! 1965 Caravel 7 11-01-2014 10:04 AM
To shower or not to shower? urbanfood Sinks, Showers & Toilets 55 07-20-2012 12:39 AM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 10:58 AM
