Old 04-22-2019, 07:36 PM   #1
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Shower pressure improvement
At a suggestion of a friend, when hooked up to water supply, I also ran the water pump and almost doubled my water pressure. Just wondering if others had tried this?
DeltaRon is offline   Reply With Quote
Old 04-22-2019, 07:58 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Typically with both of my trailers and three different shower heads over five years the water pressure at campsites has always been greater that from my water pump. Was this at a campsite that had low pressure? If the experience you described is typical, you may have a defective pressure regulator on your fresh water input.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-22-2019, 08:01 PM   #3
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
No. What Iím saying is that if you run both, water pump and city water at same time, your pressure is increased significantly. Pressure regulator is not important.
Old 04-22-2019, 09:14 PM   #4
2007 22' International CCD
Only if the water pump generates ALL that pressure. The city water inlet does not, repeat not, feed into the input of the pump. It feeds into a check valve that, when the pump runs at a higher pressure than the inlet, will cut off the flow of city water. The pump only draws water from your fresh tank.
If the city water is that low pressure, just fill your fresh tank and run on the pump.
This ďrun the pump to boost city water pressureĒ is Airstream legend, not plumbing facts...
Old 04-22-2019, 09:22 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
So if city water pressure is 65psi and my pump puts out 45psi don't I end up with 110 psi?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 04-22-2019, 09:33 PM   #6
Nope. The best you can do in that situation is about 65 pounds. The pressures donít add. Reality is the pump wonít even run. The pressure switch cuts it off at 45 pounds (or greater), in this case.
The electrical equivalent is 65 volts on one side of a diode, and 45 on the another diode feeding the same load resistor. Most you will see is 65 volts in the circuit. There will be no current (flow) from the 45 volt side
Old 04-22-2019, 09:45 PM   #7
Originally Posted by DeltaRon View Post
No. What I’m saying is that if you run both, water pump and city water at same time, your pressure is increased significantly. Pressure regulator is not important.
Yes, it is, for two reasons. 1. The pump supplies somewhere around 40 psi, and it has a pressure cutoff switch. When you use water from the tank by opening a valve, the pressure drops and the pump turns on. When you close the valve, the pressure rises (to around 40 psi) and the pump turns off. So the pump will not supply more than the pressure set by the cutoff switch. 2. The fresh water inlet has a pressure regulator valve, probably again at about 40 psi, the nominal operating range of the trailer's water systems. If the pressure from the freshwater inlet is higher than the valve's setting, it reduces the pressure applied to the trailer.
Taken together, if turning on the pump increases the pressure at the faucet, it is because the pressure available on the trailer side of the pressure regulator is lower than the pump output pressure. I'll bet you an adult beverage of your choice that your pressure regulator is bad or your fresh water inlet is obstructed somehow.
Al
S/OS #004
Old 04-22-2019, 09:49 PM   #8
Or the city water supply pressure is lower than the inlet regulator pressure setting. There is also a little check valve built into the city water inlet to keep water from spewing out the inlet if you run the pump without water connected to the inlet.
I have a regulator at the city water supply with a gauge on it at the end of my hose. I also have a gauge plumbed into my water system, just to keep an eye on what the pump and the cheap plastic regulator on the city water inlet is doing to me.
Yup, Overkill Engineering attitude. If I canít measure it, I donít know whatís really going on.
And that gauge will indicate no more that the pump outlet pressure or the output of the cheap inlet regulator. My pump runs up to about 45 pounds max, and the inlet will hit a max of whatever I set on the regulator on the supply from the campgroundóusually 40-45 pounds to keep from blowing out the fresh water hose. I never see more, only whichever of the pump or my portable regulator is set higher. I basically donít trust the cheap plastic regulator on the city water inlet.
Old 04-23-2019, 04:41 AM   #9
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Understand all comments. Now, with city hooked up and fresh water in tank, start your shower. With shower running, start your water pump and watch as your shower pressure increases. Why is my question?
Old 04-23-2019, 04:47 AM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Maybe the city water pressure is below 35?
Hereís a snip from my trailerís user manual that explains it:
Old 04-23-2019, 04:51 AM   #11
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Thanks. Water pressure reading from city is 50 psi. Still the shower pressure increased when I turn on pump. Seems strange to me. Iíve tried this numerous times at different campgrounds and it always works.
Old 04-23-2019, 10:47 AM   #12
2018 25' Flying Cloud
Portland , Oregon
Thanks. Water pressure reading from city is 50 psi. Still the shower pressure increased when I turn on pump. Seems strange to me. I’ve tried this numerous times at different campgrounds and it always works.
I’ve always done the same, turned on the pump when we take showers, because of the increased pressure. I thought what was happening was it was drawing water from both sources but now I’m thinking it is just pulling from the fresh tank and our regulator is defective or there’s a clog.
That brings me to my question. Is the regulator behind the fresh water city input on the side of the trailer or somewhere else?
daleyocum is offline   Reply With Quote
Old 04-23-2019, 11:51 AM   #13
The factory installed regulator is a clear plastic part on the back of the city water inlet if itís original.
Yup, if running the pump increases pressure, you are using the contents of your fresh water tank. Many times, the pun is set to run at about 60-65 pounds or so.
Thatís why I suggest that itís easier to just fill the tank in a campground with low water pressure, and just run the pump.
As a side note, always use a filter either on city water, or filling the tank. It helps keep fine particles and other nasty stuff out of your water system.
Old 04-23-2019, 02:41 PM   #14
2019 27' Globetrotter
Denver , North Carolina
I'm taking a wild guess here. You say the city water pressure is 50psi so I'm assuming you have a pressure regulator at the campgrounds spigot. What you or any of us don't know is what is the pressure after the trailers pressure regulator unless you have installed a pressure gage down stream from that regulator.
My guess is your pump is providing more pressure than your trailers city water regulator is allowing therefore increased water pressure when you turn the pump on.
Dave S
link2dks is online now   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Little Adjustment, Big Improvement! thecatsandi Hitches, Couplers & Balls 2 06-08-2006 08:34 AM
Bambi Improvement Request DreamStream Our Community 2 01-24-2004 08:46 PM
Frustration_forum improvement ? femuse Our Community 24 03-27-2003 03:58 PM
