Old 11-20-2012, 04:52 PM   #1
2013 22' FB Sport
Ventura , California
Question Shower Leaks
We have a 2013 22' Sport. Our shower leaks along the bottom of the shower rail that guides the accordian shower enclosure. The aluminum rail has small holes to drain the water back into the shower, but it seems to pool in one corner and drains onto the floor. We also noticed water puddling in the shower pan in that same corner of the shower ( along the shower inclosure rail ), instead of moving towards the drain. Could the factory installation of the shower pan be installed incorrectly? Or has anyone else had this problem? HELP and THANKS
laulenta is offline   Reply With Quote
Old 11-20-2012, 05:02 PM   #2
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
You could drill a small hole in the rail at the corner that its pooling. A small pool in the bottom will be more likely common then not depending on how level the rig is when used. It won't take much out of level to cause this.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 11-20-2012, 05:03 PM   #3
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
laulenta: Is your trailer perfectly level?......that's important on many levels.
Del Gurney is offline   Reply With Quote
