Old 07-20-2015, 10:35 PM   #1
kstewart23's Avatar
2011 27 FB International
San Antonio , Texas
Shower leak question
We have a 2011 international signature 27fb the shower is separate from the toilet/sink area. On the last night, last shower of our last outing water began leaking from under the shower into the hallway. I asked my husband if he had turned the shower head so that the water was running down the wall onto the faucet handle, he said yes, so I thought maybe the water was making its way behind the faucet handle and coming out under the shower and into the hallway. It doesn't appear to be sealed with silicon or anything. And the water is definitely not leaking from the shower door. Anybody have this issue? I really hope its not something else.
kstewart23 is offline   Reply With Quote
Old 07-20-2015, 10:56 PM   #2
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
On our 2015 28FC, we had a leak around the shower and I pulled the access plate off the back of the shower to examine. Turned on the water and all looked fine around the valve. However, when you would press the button on the shower handle to get a stream of water, it leaked tremendously from the connection behind the shower. Easy fix in that the mothership had used a too thick of shim and the connection didn't seal completely. On yours, it could be the connection just loosened up over time from use. Simple to tighten and no more leak. On ours, I put a thinner shim in and it then mated well. No more leak. Only occurs when actual shower handle is turned on. Just having water on in shower it will not leak.
Don't know if that's your issue, but might be a starting place.
Chuck
silverlabs is offline   Reply With Quote
Old 07-22-2015, 05:02 PM   #3
Strasser's Avatar
2010 23' FB Flying Cloud
NA , Here and There
Hello!
We had this same issue soon after we bought our used Airstream.
Fortunately, it was as easy as re-caulking the shower. The water was leaking through the crack half way up the wall (image attached).
We used GE Silicone II.
Hope this helps!
Strasser is offline   Reply With Quote
Old 07-22-2015, 05:13 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Mine was leaking between the interior plastic flashing and the shower door frame. I removed the flashing and show door framed and resealed.
Kelvin
Shower leaks behind shower surround Divemaster10 Sinks, Showers & Toilets 6 05-15-2018 03:21 PM
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
To shower or not to shower? urbanfood Sinks, Showers & Toilets 55 07-19-2012 11:39 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
30' WB shower leak question flynmike Sinks, Showers & Toilets 0 06-18-2006 06:32 PM
