Old 03-14-2019, 01:46 PM   #1
2016 30' Classic
shower door seal replacement
I have a 2016 Classic 30 and I purchased an extended warranty. Airsteam of Tampa just informed me that the warranty company declined the repair of the shower door seal. My question isn't about the very expensive bumper to bumper warranty I purchased from them but rather about the time I was told it would take to perform the service. Airstream of Tampa told me the part is about $10.00 but it would take "every bit of 4 hours to replace it" at an hourly rate of $150.00. By my calculation, that's an out of pocket repair cost of $600.00 for a $10.00 part. Am I missing something here?
CMTampa is offline   Reply With Quote
Old 03-14-2019, 02:09 PM   #2
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
That is my definition of highway robbery. I haven’t tackled my AS door seal but on an SOB it took me 30 minutes tops. If j couldn’t do it myself, I’d find a good mobile RV certified mechanic. They’re around
WW
By being so focused on how things 'could' be, we are under-appreciating how great things already are - Timber Hawkeye
Wolfwhistle is offline   Reply With Quote
Old 03-14-2019, 02:10 PM   #3
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Is this the seal (gasket/rubber strip) that runs along the bottom of the shower door?
If so, fuggetaboit!! Itís a waste of time to repair/ replace. We did ours twice only to have it shear off again.
Your better off with a shower curtain inside the door.
No leaks and the door stays clean.
az-streamer is offline   Reply With Quote
Old 03-14-2019, 02:19 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Wear and tear items are not typically included in warranties, extended or otherwise. Rubber seals, gadgets, and the like are generally considered wear and tear items.
If you could provide some additional color around what seal in particular is having an issue, folks not he forum can help assess what the true effort is to replace.
If it is the clear plastic sweep that sticks to the bottom of the shower door, well that would be a $10 part and it takes about 60 seconds to replace (I've done this on my 2017). Typical maintenance item that one deals with every 2-3 seasons.
What seal exactly is giving you an issue?
wulfraat is offline   Reply With Quote
Old 03-14-2019, 06:54 PM   #5
2017 23' International
hendersonville , North Carolina
Shower door
Get rid of the solid door. Matter of time before it breaks the top mounting point and falls off . Suggest you replace solid door with "Nautilus" shower door by Stoett Industries. This door is used in the 23D shower and it is excellent. We have one in our 2017 Int. Serenity 23D and has been perfect. No leaks at the bottom. Cleans easily. Retracts into holder and is completely out of the way. Kind of like a pocket door. Check it out. May solve your current problem and also save you from broken door situation in the future.
It would be pretty easy to remove current door and install this door.
uraljohn is offline   Reply With Quote
Old 03-15-2019, 09:47 AM   #6
2018 27' Flying Cloud
Atlanta , Georgia
The rubber gasket just got in the way. We took it off and could not see any water coming through. It is just a nuisance.
jnm30327 is offline   Reply With Quote
Old 03-15-2019, 09:48 AM   #7
caz
2018 30' Flying Cloud
Elgin , Texas
If the seal discussed is the plastic sweep across the bottom of the door, ours got tore up when the door frame collapsed down vertically. Dealer replaced the door assembly under warranty but forgot to replace the bottom sweep. Guess what? the door works fine without it. No drips on the floor. Caz.
caz is offline   Reply With Quote
Old 03-15-2019, 10:10 AM   #8
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
If it’s the rubber one across the bottom, Airstream sent me a replacement free long after the warrantee expired on my Flying Cloud. I’d searched all the local stores and couldn’t match it. There was no parts number so I sent AS a photo and the great lady in parts matched it.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 03-15-2019, 11:21 AM   #9
2016 30' Classic
Victoria , British Columbia
Our shower door sweep lasted a matter of minutes. I picked up two spares, but have found that without the sweep gasket the metal lip below the door keeps the water within the shower. The installation takes several seconds, as it simply slides into a channel at the bottom of the door. I put a very small bit of clear silicone grease on the top of the sweep, and it quickly slid into the channel. The replacement lasted less than a week.
To quote 4 hours labour, the dealership must have misunderstood your issue, and quoted the labour to install a new complete door. Or they are being completely dishonest.
Camr is offline   Reply With Quote
Old 03-15-2019, 11:40 AM   #10
1995 34' Limited
Sarasota , Florida
Sanders RV in Alachia, Fl is the only place I have heard and know of in Fla to have satisfied repair or parts accomplished
GatorDave is offline   Reply With Quote
Old 03-15-2019, 11:41 AM   #11
2013 27' FB Classic
Crestview , Florida
Uraljohn and nautilus
I read your response on the nautilus shower door and it looked interesting. I measured my door frame width and it was 25.5 inches. On their site the most narrow door they show is 36 inches. Is the shower door on your Serenity 23d actually that wide or did you have one special made?
Thanks...
david1622 is offline   Reply With Quote
Old 03-15-2019, 11:57 AM   #12
2006 28' International CCD
Saint Paul , Minnesota
We've had 3 shower doors all poor design and subject to many problems, too heavy and flawed design. Expandible shower rod and interesting curtains (we carry several for a change of scenery) solve the problem. Nautilus seems to work in other trailers as do the accordion type made of plastic which are much lighter and less subject to failure.
Mhphhoward is offline   Reply With Quote
Old 03-15-2019, 03:24 PM   #13
2002 19' Bambi
Lafayette , California
Our 2002 19' Bambi came with a door like the Nautilus one. That door has worked perfectly since we bought the trailer new. It has been necessary to caulk the bottom strip a couple of times. I believe our door is from Newline-Shub (http://www.newlinebathroom.com/shub---rv-c-1.html) and it seems to be very similar in function to the Nautilus doors.
Tim
Tim A. is offline   Reply With Quote
Old 03-15-2019, 04:16 PM   #14
2015 30' International
FREDERICK , Maryland
We got tired of the shower door seal tearing and coming loosed. Removed the torn seal 2 seasons ago and still not leaking.
Doc Foster is offline   Reply With Quote
Shower Door Bottom Seal Failure cptfish Sinks, Showers & Toilets 2 01-28-2015 07:02 PM
Shower Door Bottom Seal replacement for 2012 27FB jasperkins Sinks, Showers & Toilets 3 10-27-2013 09:24 AM
Shower Door Seal Repair Airstream12557 Land Yacht/Legacy Motorhomes 0 01-23-2013 03:11 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
