Old 03-15-2019, 07:00 PM   #15
2017 23' International
hendersonville , North Carolina
Shower door
Originally Posted by david1622 View Post
I read your response on the nautilus shower door and it looked interesting. I measured my door frame width and it was 25.5 inches. On their site the most narrow door they show is 36 inches. Is the shower door on your Serenity 23d actually that wide or did you have one special made?
Thanks...
The rough opening for door in our 23D is 28". This is a factory installed door. All 23D (now called 23CB) have this door as well as the 19' Airstreams. If you remove your door including all metal framing the opening may be slightly larger. A 36" door would work fine. It just would not fully extend in your opening. In the kit it comes with you would have to trim the top and bottom rails to fit your opening. Easy to do. If you have an Airstream dealer within a reasonable distance go take a look at a 23CB.
uraljohn is offline   Reply With Quote
Old 03-15-2019, 08:21 PM   #16
Sue.
Rokitman is offline   Reply With Quote
Old 03-16-2019, 05:07 AM   #17
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
The Nautilus door.... You would buy the 36" door of your choice and the horizontal parts "B" would be cut to fit. Download instructions to see how.
https://23wkb321i0b1he1544a1dfsuvi-w...d-Warranty.pdf
Clint
By being so focused on how things 'could' be, we are under-appreciating how great things already are - Timber Hawkeye
Wolfwhistle is offline   Reply With Quote
Old 03-16-2019, 11:05 AM   #18
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Clint
Yep, did just that and trimmed the top and bottom rails. Makes the whole trailer feel bigger and no"'door wars" between toilet and shower.
Old 03-16-2019, 07:23 PM   #19
2017 19' International
Tallahassee , Florida
What is the deal with Airstream's shower doors?
The one in our 2017 19-footer leaks and I can't find a way to keep things dry.
And, it has come loose at the top. What the ...?
WhereStream is offline   Reply With Quote
Old 03-16-2019, 09:52 PM   #20
2018 28' International
Fayetteville , Georgia
Replaced the seal on the shower door. Took maybe 5 minutes. It press fits on my 2018 Serenity 28
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 03-19-2019, 10:59 AM   #21
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Just received my kit from airstream to prop the door up.... for those who are interested...
wulfraat is offline   Reply With Quote
Old 03-19-2019, 01:37 PM   #22
Kensington , Maryland
Thanks Wulfie. Perfect.
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 03-20-2019, 02:59 PM   #23
2015 27' Flying Cloud
Washington , Washington, D.C.
To answer the OP’s original question: this is a known issue with the shower door. I think Colonial Airstream sent me one for free or very cheap. Replacement takes a few minutes. It is not necessary to remove the door. Never noticed water getting outside the shower, before or after the replacement. We have a handheld shower. The idea is to get water on yourself not the door. Admittedly, we don’t use the shower foe hair washing, which might get more water around, and also do a much better job of filling your grey tank and depleting your water supply.��
Of course, some folks view their trailers as a continuing project; others just use ‘em to go camping. So I’m sure there’s all kinds of stuff that can be done, but we’re in the “camping” group. Don’t sweat this one, and don’t pay gobs of money for someone to fix it. Buy some fuel for your TV and go camping! ��
DC Bruce is offline   Reply With Quote
Old 03-20-2019, 04:25 PM   #24
Arlington Heights , Alabama
This is not about shower doors but it is about Aistream service. We needed new axles, Airstream said it would take every bit of 4 days to get it done. Bought the axles directly from Dexter and they shipped them to a local shop. 2.5 hours labor to install them, axles, brakes, bearings, spindles, the whole thing.
janicemd is offline   Reply With Quote
Old 03-20-2019, 10:49 PM   #25
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
Originally Posted by GatorDave View Post
Sanders RV in Alachia, Fl is the only place I have heard and know of in Fla to have satisfied repair or parts accomplished
And I vouch for that. Bought mine at Tampa RV. Now go to Sanders for anything! They’re the best!
"All good things are wild and free."Henry David Thoreau
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 03-21-2019, 07:12 AM   #26
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Easy Fix
We’ve had numerous problems with shower doors and have had to replace twice. It always starts with the shower sweeps tearing. Then the door won’t open and close properly without lifting it. The repeated lifting over time will cause additional problems and eventually, if not fixed, the door will fall off
Good news! We finally figured out the fix and it cost less than a dollar. We bought a 3/8 inch nylon lock nut and placed under the lower door hinge. This holds the door up (after the shower sweep starts tearing) and allows for smooth open/close operation without having to lift the door. And, even though the sweep is torn, there are no water leaks when showering. Wish we would have figured this out sooner: would have saved us significant $’s and tons of investigation.
demijac is offline   Reply With Quote
Old 03-21-2019, 07:16 AM   #27
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Are you thinking that Airstream should stock all of the axles, brakes and bearings for all of the trailers that they have made. I would think that they would order them in from Dexter, just like you had to do.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 03-21-2019, 11:50 AM   #28
2002 19' Bambi
Lafayette , California
Originally Posted by Adventure.AS View Post
I would think that they [Airstream] would order them in from Dexter, just like you had to do.
Ordinarily I hate to add to a thread hijack, but (just as Adventure.AS probably felt the need to do) I can't let this one go .
I can confirm that Airstream also orders from Dexter. Not quite a year ago, I ordered a new axle for our 2002 19' from our local Airstream dealer. When it arrived, various labels clearly showed that it had just been ordered by Airstream from Dexter.
Tim
Tim A. is offline   Reply With Quote
Shower Door Bottom Seal Failure cptfish Sinks, Showers & Toilets 2 01-28-2015 07:02 PM
Shower Door Bottom Seal replacement for 2012 27FB jasperkins Sinks, Showers & Toilets 3 10-27-2013 09:24 AM
Shower Door Seal Repair Airstream12557 Land Yacht/Legacy Motorhomes 0 01-23-2013 03:11 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
