06-24-2016, 07:30 PM
#21
2013 25' FB International
Liberty Corner
, New Jersey
franklyfrank,
I find myself thinking the same about what might have happened had I read this forum first. It at least has given me a better understanding why some consultants involved with manufacturing improvement laughed at me for getting an AS.
06-24-2016, 09:27 PM
#22
2012 25' Flying Cloud
Battle Lake
Okay, here's the 20 minute CorrosionX treatment.
Take the spray can and spray along the rivet lines and panel edges. Let in soak a couple of minutes and wipe it up. Spray the underbody steel parts and let them be. You're done and your Airstream has great corrosion protection.
If you live and camp in the desert do it every couple of years. If you live or camp at the beach or pull it through northern road salt do it more often.
Doug and Cheryl
06-25-2016, 05:06 AM
#23
Displaced Beach Bum
2016 30' International
Texas Airstream Harbor
How much Corrosion X does it take to treat a fairly new 30'
We drag Mitzi a 2016 International 30 w/Goodyear Endurance, Equalizer 1000, pulled by a 2018 GMC Sierra 1500 SLT 4x4, Crew Cab, 5.3L V8 ECOTEC3, 3.42 axle, 8 speed auto WBCCI #6111
06-25-2016, 06:54 AM
#24
Battle Lake
One spray can should easily do, but CorrosionX (and/or Boeshield T9) are good general purpose lubricating and penetrating oils. We carry a can in our Airstream on our long travels. Buy two.
I mentioned earlier dabbing the rivets with a Q-Tip dipped in CorrosionX. That method didn't receive rave reviews but takes much less than 1/4 can.
Doug and Cheryl
06-25-2016, 08:38 AM
#25
Something Shiny
2017 27' International
Mosinee
, Wisconsin
Originally Posted by dkottum
We've been using CorrosionX on the shell and Boeshield T9 on the underbody steel parts for five years, no corrosion anywhere on our Airstream. We must qualify that by saying we have not driven in northern winter road salt or camped near near the salt water coasts.
So we've had a two-part prevention program, use corrosion prevention products regularly and avoid salt environments as much as possible. Most people will not be able to avoid the salt environments or want to, so frequent washings and corrosion prevention products should be used more often.
The filiform corrosion will start anywhere the factory shell coating is compromised, panel edges, holes drilled for rivets, nicks and scratches, exterior accessories such as tail light housings, hinges, locks, and wheels.
We set up a program where we inspect the trailer once a quarter for condition and operation, treat the shell edges, rivets and accessories with CorrosionX, and the underbody steel with Boeshield T9 or CorrosionX.
We took a felt-tipped clear acrylic touchup pen and run it along the panel edges, probably four times letting them dry between applications. That seems to protect the panel edges, spray the CorrossionX onto accessories and wipe up with a rag, and do the rivets with a Q-Tip dipped in CorrosionX. I only treat the panel rivets, the window/door frame rivets I wipe with a CorrosionX on a rag.
Then spray the underbody steel, such as steps, spare tire mount, stabilizers, and axles being careful to never get any into the brake drums.
We started this process the day we brought the Airstream home, it's very simple, takes maybe an hour or so a few times a year.
Do you wax? If so, do you wax before or after the CorrosionX process?
2.
06-25-2016, 09:14 AM
#26
Anna Maria
Originally Posted by TheCabin
franklyfrank,
My biggest gripe is with Airstream. I feel that it is their responsibility to manufacture a worry free product. If it is prone to corrosion and needs preventative measures they should install it at the factory. I feel the same way about them re, installing GYM tires and 15" wheels. They should make the 16" wheels and Michelin tires a standard as well.
After all they charge a small fortune for these trailers. I am willing to pay it but in return I want to simply hitch up, go traveling without worrying about corrosion damage an tire thread separation. Pay 90 grand for it and end up with non stop anxiety owning it.
06-25-2016, 09:20 AM
#27
Anna Maria
Before doing that I surely need to wash it because you can't wipe over dirt without scratching the finish.
I might give that a try the next time I wash it, providing I have enough energy left. Or maybe just stop fretting over it and let the next owner worry about it.
#28
Displaced Beach Bum
I see it much like owning a home, you have to clean it, cut the grass, prune the trees and bushes. Every few years you have to paint it. Have to change the oil in your car, wash it, rotate the tires... that's life!
You could have purchased SOB for a lot less and every 10 years just give it to someone...
06-25-2016, 09:29 AM
#29
Anna Maria
Originally Posted by rmkrum
Seriously, it's NOT that big a deal. Our AS was stored outdoors in WA state for years. Very little filiform corrosion. I don't obsess about it. I'm 68, if the AS gets washed at all, it's every couple years. I don't obsess about shiny. I go camping.
😀IMHO some folks on the forums (a minority) are way too worried about the looks of their vehicles.
That is basically my motto as well. I do try to wash it every 4 weeks or so simply because I like it clean looking but otherwise I do not fret over the thing.
Once I got past the first few dings and scratches and realized it didn't affect our enjoyment of it at all I learned to relax and enjoy.
06-25-2016, 10:40 AM
#30
Battle Lake
Who's fretting, it's just routine maintenance. I've had cars that rust, houses that need paint, guns that need cleaning, a body that had cancer. Preventive care helps them all, and sometimes they need fixing anyway.
Doug and Cheryl
06-25-2016, 11:42 AM
#31
Displaced Beach Bum
Has anyone tried CorrosionX HD (Heavy Duty) aka Amber?
06-25-2016, 12:06 PM
#32
2012 25' FB Flying Cloud
Boise
, Idaho
[QUOTE=Pongo;1811206]Do you wax? If so, do you wax before or after the CorrosionX process?
I wash, apply Corrosion X then wax
06-28-2021, 04:22 PM
#33
2021 27' Globetrotter
Daytona Beach
Bump............
Are ya'll still using Corrosion X and treating your rig the way this thread is saying or have things changed in the last 5-6 years with finishes and or products used to treat these issues. Thanks.
06-29-2021, 10:19 AM
#34
Boise
, Idaho
I’m still using the same protocol. No issues for 10 years.
06-06-2022, 05:39 PM
#35
2022 25' International
Savage
6 years later, this is still great advice.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
06-07-2022, 02:07 PM
#36
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
A different approach....
....with the shield & bio stuff.
I use both and went after the filiform religiously for the first 4-5 years.
Every outbreak was stopped in its tracks.
I noticed the after all the original compromised panels revealed themselves the new outbreaks were now the result of road or self damage to the clear-coat. VERY few new rivet or seam filiform was happening.
I wash several times a season, inspect often.
And use a surface sealer,(Griots One step) every Spring.
IMHO...
The methods used are not as important as using the method chosen.
03-24-2024, 06:41 AM
#37
2024 28' Flying Cloud
Jackson
, New Jersey
X2 - anybody using the HD variety? Worth it?
2023 F250 Lariat Supercab SB 4x4 7.3l 3.73 148” WB
Ordered: 2024 FC 28RBT, scheduled to build 5/16
03-24-2024, 07:45 AM
#38
2022 25' Flying Cloud
NCR
, Ontario
also give this product a try
CRC 06026 Heavy Duty Corrosion Inhibitor
provides effective protection for steering & throttle linkages
Extended corrosion protection
Seals out moisture
it works for us
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
03-24-2024, 08:27 AM
#39
Jackson
, New Jersey
Actually I just read the HD version of CorrosionX goes on as a tacky brownish film; so no go on the HD.
03-24-2024, 09:37 AM
#40
2017 25' International
Joliet
I tried the HD on my snowmobile trailer axles once. It's like spraying honey on everything. Goes on thick. Collected a lot of dirt too. Now I just stick with the regular stuff and use it on my truck frame,trailer axles and chains a couple times a year.
