10-01-2014, 07:53 AM
2007 27' Classic FB
Fredericksburg
Shocking Discovery
Yesterday I was checking things under my AS prior to a trip and found that the nut was missing that holds the upper mount for one of my shocks. Don't know how long it has been missing. The shock was about one half of the way off of the mounting stud. Something else you should look at from time to time.
The Tex-i-can is Ready to Camp
10-01-2014, 08:13 AM
2014 30' FB FC Bunk
Hoover
, Alabama
oh wow...I am mechanically not all that intelligent...but for "fun" may I ask:
What happens when a shock falls off?
10-01-2014, 08:40 AM
1987 32' Excella
Nepean
, Ontario
The shocks are mounted horizontally, so it depends which stud it comes off of. If the front stud, the shock will drop and dig into the road while you drive and the damage it does to the trailer can be major. If the rear stud, it will drag along the ground, throwing up sparks; also not desirable.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
10-01-2014, 09:07 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
This sounds like a job for Loctite Thread Locker™!
10-01-2014, 09:37 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Use blue instead of red Loctite as you might need to replace the shock in the future.
10-01-2014, 10:18 AM
From All Over
New shocks would come with new nuts, though, so if you have to cut off the old ones, no harm done, as long as you've got the tools and the skill for it.
10-01-2014, 11:15 AM
1964 26' Overlander
Richmond
, Virginia
I used the nuts with the vinyl thread lock in them for that.
10-01-2014, 12:41 PM
Oswego
Also, just a little torch heat will release red loctite. And I don't mean red hot either.
-Rich-
10-01-2014, 01:59 PM
2000 23' Safari
Vero Beach
Sometimes it takes a "nut cracker" to get the rusted nuts off. Yes, it does exsist and does not crack walnuts! You can get them at stores like Harbor Freight and maybe Sears. I worked on air cooled Volkswagens so I am quite familiar with them!
10-13-2014, 07:35 PM
1977 25' Tradewind
Strongsville
, Ohio
Found plenty of nuts in mine tonight!
10-13-2014, 07:42 PM
King of the Zebra Speedo
Obrien
Yowza! Squirrel or rats?
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
10-13-2014, 07:44 PM
1977 25' Tradewind
Strongsville
, Ohio
Squirrel, eyeballed him as he jumped from the overhead and dove in behind the commode for his escape
