Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-30-2008, 09:22 PM   #1
crdouger
crdouger's Avatar
Profile:  1960 22' Safari
Rockford , Michigan
Share some cool custom improvements
I love seeing people do things that are cool and innovative and simple and trick...but are home grown. I'd love it if some people would share what are the improvements that they are most proud of in their airstream. Please include pictures if you can.
Doug
crdouger is offline   Reply With Quote
Old 09-30-2008, 09:50 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I installed an electronic household thermostat for our Armstrong a/c. The entire unit now turns off when it reaches set temp, it is much quieter.
Old 10-06-2008, 06:51 PM   #3
Doogie521
Profile:  1970 23' Safari
Grant , Michigan
How about a stereo with NOAA radio
Hi Doug,
I am also a Doug and live close to you (Grant) one thing I wanted in my 70 Safari was a NOAA weather radio. I found one on ebay meant for marine applications - that had an am/fm and cd along with 3 weather bands. I added some 6x9 blaurpunkts for good sound! And of course that overhead compartment was just begging for a stereo to fill it's void.
Doogie521 is offline   Reply With Quote
Old 10-09-2008, 09:14 AM   #4
jeff4506
Profile:  2005 25' Safari
Hilliard , Ohio
I have the audio upgrade package and I installed a switch to interrupt power to the head unit, CD changer and Satellite radio to save power. Very simple. These devices slowly leech power even when not in use. Also, I installed a 12 volt power port inside the refrigerator access area to facilitate tire pumping with a 12 volt compressor. Again, quick. Both under $10.
2005 25' Safari LS
jeff4506 is offline   Reply With Quote
Old 10-09-2008, 12:08 PM   #5
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove , California
Our 1965 17' Caravel has four Toyota car jacks attached to the frame. Each jack os located about 2/3 the distance from the axle to the outer end of the frame rail. Whan the jacks are extended, the trailer is not only "steady as a rock", but can be leveled from side to side. Now.... I always get the trailer level or nearly level side to side before extending the jacks, but lifting one side a small amount has never been a problem. When not extended, the jacks protrude only about three to four inches. No clearance problem at all.
Really handy, as storage space on a Caravel is at a premium.
Old 10-09-2008, 12:53 PM   #6
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Well D'oh.... 12 volt inside reefer access ---- LOVE IT!
Paula
Today is a gift. That's why they call it "the present"
Foiled Again is online now   Reply With Quote
Old 10-10-2008, 07:28 AM   #7
crdouger
crdouger's Avatar
Rockford , Michigan
Doug...I love the 12v power access idea. I'll have to remember that. At first I thought you were saying that you installed it INSIDE the fridge. I couldn't figure that one out.
I've also been looking into the car jack concept under my 22' safari. I don't want rip them off at the end of my driveway...so I'll have to install them back a little bit too.
Keep the good ideas coming!
I needed to rebuild my kitchen table in my front dinette area. It came with one leaf to extend the table while you were eating and then shrink it when I need to make it a bed for my kids. When I rebuilt it, I made it even shorter and made two leaves. Now I can shrink it down to the size of a little end table during the day so we can more easily sit down to put on shoes or get dressed.
Old 10-10-2008, 07:55 AM   #8
markdoane
Profile:  , Minnesota
Images: 59
I bought some of those Xenon puck lights (3 for $20). Mounted them in the overhead and wired them to a marine light switch so I can turn on just one, or all three.
These put out a ton of light. I'm looking for an inexpensive DC dimmer switch to make them a little more romantic. Needs to handle 60 watts.
Name:	Overhead lights 001.jpg
Non-contributing deadbeat.
Old 10-10-2008, 09:43 AM   #9
purman
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
You can see my custom bunks here along with the dinette...
Remodel of my 68' Ambassador.
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
'89 Jaguar XJ6
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-10-2008, 11:22 AM   #10
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I might have extrea dimmer switches in a month or so.
You might be able to fit 5W or 10W xenon lamps in the pucks to bring down the light output, ,depending on which lamp is in there now. You said 60W, so I assume you have 20W lamps in the fixures..
Uwe
Old 10-10-2008, 12:03 PM   #11
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
The lights sure look nice, Mark. Did you just hide the wiring in the cabinets behind them?
Stephanie
Our family photo blog
Old 10-10-2008, 12:33 PM   #12
markdoane
Images: 59
Uwe,
I'd be interested in the dimmers, or even just a mfg and PN. I found some cool schematics but they need a power transistor and a couple of amplifiers.
Stephanie, yes I ran the wires through a rabbet in the cabinet, and touted them to the light switch on the pantry wall.
Old 10-10-2008, 12:53 PM   #13
tphan
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
One thing I did was make more countertop space- we like to cook and I've yet to see a tt with enough food prep area. I did this by getting rid of the original fridge-vent enclosure, and by extending the lower cabinet and countertop. Some day we might have a small convection oven in the corner.
tphan is offline   Reply With Quote
Old 10-10-2008, 01:18 PM   #14
Stefrobrts
Stefrobrts's Avatar
How did you do that brushed aluminum backsplash, tphan? That looks really nice! We have the yellowed, cracked plastic fridge vent on ours, I've been looking for an easy way to hide it.
Stephanie
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 09:20 PM
Share your favorite roadfood spots 63air On The Road... 56 05-09-2008 11:23 AM
Using OnStar phone with Family Share minutes Airstream25 On The Road... 2 07-01-2006 09:32 AM
Thought I would share this info. rebel beck Axles 15 06-07-2006 09:29 AM
Share in my sentimental joy -- our WBCCI number PWRSTRK WBCCI Forum 5 01-10-2005 10:42 PM
