Old 10-04-2015, 05:50 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Sewer hose Storage
Has anyone found a simple solution to compressing sewage hoses for storage? I carry long med and short hoses. Getting them crammed into the drawer is a real pain after they're out of the box.
Emh142 is offline   Reply With Quote
Old 10-04-2015, 06:06 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Try this… Get a piece of PVC pipe that is small enough to fit inside the slinky but large enough to almost fill the slinky. Cut it to the same length as your compressed slinky or just slightly longer. Mount a flange permanently on one end of the PVC pipe to keep the slinky from sliding off. Make sure the outside diameter of the flange is still small enough to fit into your existing slinky storage tube.
Use another flange for the other end, but don't fasten it on; a slip-fit is fine. Once you have slid the PVC pipe into your slinky, a lightweight bungee cord from one flange to the other will hold the slip-fit flange in place, and make the entire slinky into one solid compressed tube that's easy to handle. If the bungee would be in the way of fitting the thing inside your storage tube, you can run the bungee cord inside the PVC pipe, but running the bungee on the outside if there's room also turns the bungee into a convenient carrying handle.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-04-2015, 06:18 PM   #3
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Sewer hose storage
How about this? Added this to mine - easy to do.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 10-04-2015, 06:20 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine has two of those tunes under it. I also did this:
Drill a hole in the storage tube about an inch from the end and another 180 degress across from it. Stuff the hose in the tube and then put a piece of bent coat hanger thru the holes to keep the hose from trying to pop out while you put the cap on.
CRH is offline   Reply With Quote
Old 10-04-2015, 06:28 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Rear bumper box. Three pieces, 40 ft total. Fits with room to spare.
MICHAEL
Old 10-04-2015, 06:32 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
The rear drawer is where I keep my fresh water hoses.
Old 10-04-2015, 07:30 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Many if us have given up the slinky in favor of a Sewer Solution. Just a 3/4" hose. Drains the tanks slower at the RV dump but easy and clean to use and store.
Doug and Cheryl
Sewer hose storage JMSx2 Land Yacht/Legacy Motorhomes 12 09-19-2013 02:19 PM
Lost my sewer hose storage tube cap Jack46 Exterior Storage Compartments & Access Doors 18 08-15-2013 07:14 AM
Sewer hose storage on Safari mgap 2004 Safari 5 05-08-2013 10:09 AM
How can I repair or replace sewer hose storage pipe? Acker997 Waste Systems, Tanks & Totes 10 06-27-2010 01:17 PM
Sewer Hose Storage Options 66Overlander Waste Systems, Tanks & Totes 2 07-21-2007 08:30 AM
