Old 10-03-2016, 11:15 AM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
sewage/sulfur smell
Was winterizing the AS, when I drained the hot water tank got a strong odor of sewage/sulfur? Concern? Or just from the water sitting for prolonged period?? Any thoughts? Thanks
mwilliamsmd is offline   Reply With Quote
Old 10-03-2016, 11:37 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Not to worry. The anode in the water heater has deteriorated and needs to be replaced. Do that and run the system for a while to flush it.
Old 10-03-2016, 01:02 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I do not believe the water heaters currently used by Airstream still use anodes. Tank materials used no longer require them. My 2006 does not so going out on a limb and guess newer one also no longer use them.
Fill and drain the water heater using light bleach mixture a couple of times. Should be fine. Always a good idea to use the water in fresh water tank and water heater regularly.
MICHAEL
Old 10-03-2016, 03:34 PM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
The anode rod is one of a few possible sources of hydrogen sulfide gas, that rotten egg sewer smell from a water heater. Could be directly from a well water source, or could be due to sulfate reducing bacteria taking up residence in your water system. Either way, AWCHIEF's advise is spot on. Flush with bleach, which will oxidize any remaining hydrogen sulfide and kill any bacteria.
TheGreatleys is offline   Reply With Quote
Batteries smell like sulfur and won't hold a charge Eltee General Repair Forum 2 01-10-2016 07:28 PM
Sulfur smell plmulhern Sprinter and B-van Forum 10 05-23-2015 01:11 PM
Outside Sewage Smell timmy67 Waste Systems, Tanks & Totes 9 08-05-2008 12:57 PM
Battery Sulfur Odor spat61 General Motorhome Topics 2 12-29-2007 05:56 PM
Rotten egg / sulfur smell niss1679 Electrical - Systems, Generators, Batteries & Solar 17 10-17-2005 06:08 PM
