Old 01-03-2009, 11:27 AM   #1
1981 25' Excella II
Bristol , Bristol
Serial Number
I'm looking to purchase a 1981 Excella II in the UK, but can not locate serial number. Anyone know where it should be located. Looked in manual, it states what infomation it contains, but not its location.
budgie is offline   Reply With Quote
Old 01-03-2009, 11:29 AM   #2
Should be stamped into the A-frame and on a small plate at the lower left side, near the front.
No serial number find, usually indicates a stolen coach.
Old 01-03-2009, 11:34 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
The VIN should be on the title, stamped into an aluminum badge on the outside just to the right of the door, and possibly (not always) stamped into the front A-frame. The latter could be on the curbside box beam top or side just behind the propane tanks; this could be partially obscured by weight distribution add-on equipment, paint or other modifications in this area.
My '74 Argosy VIN was on a plate just below the front window. My '06 Safari VIN is on a plate just above the rubrail on streetside front.
5 meter Langford Nahanni
Old 01-04-2009, 05:14 AM   #4
1981 25' Excella II
Bristol , Bristol
Many thanks for the information, found badge on front just below window. A-Frame has been altered to meet Europe regulations. Anyway I am now the proud owner of a Excella II. I'm sure I will be seeking further advise as time goes by.
Old 01-04-2009, 07:09 AM   #5
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Welcome!
Well, welcome to the world of "caravan" travel. We probably won't get you to many or our Forum Rallies, but do drop in to chat. People here have an astounding body of knowledge about these aluminum toys and are always happy to help a fellow "Streamer."
AirsDream is offline   Reply With Quote
serial number identification? Tad Pole General Repair Forum 2 08-20-2008 07:40 PM
serial number confusion xrvr 1969 - 1973 Safari 11 02-20-2008 11:16 AM
Serial number JBK 1969-1971 Caravel 3 01-25-2007 07:08 PM
Serial Number Plaque 61Bambi Clearcoat, Exterior Paint & Trim 1 02-13-2004 08:16 PM
Serial number plates till Title, VIN & Registration 3 01-19-2004 07:42 PM
