Old 06-09-2015, 08:18 PM   #15
Napking
Skee75's Avatar
2015 30' International
Plymouth , Minnesota
You're a rock star.
Thanks for the help.
Skee75 is offline   Reply With Quote
Old 06-10-2015, 03:06 PM   #16
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
+1 for sure.
As a relative newbie, I can't even think about putting a drill to my roof!
DoublTrouble is offline   Reply With Quote
Old 06-13-2015, 02:16 AM   #17
Msmoto's Avatar
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
One point I need mention....... It takes me about three or four times as long to do these modifications as a shop might require. And one of the time consuming factors is planning, then allowing an overnight period, more evaluation of plans, rechecking, and finally going through each step making certain even if I screw up royally there is a way to fix the problem.
Drilling a 2 1/4" hole through the roof......may increase the quality of my spiritual life as well😂😇
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 06-13-2015, 10:12 AM   #18
Msmoto,
Please don't get me wrong...
I am truly impressed and admire your skills and of course the finished product!
Great stuff.
Old 03-07-2016, 07:55 PM   #19
Napking
Skee75's Avatar
Msmoto, after the pilot hole is through the interior ceiling, could I use the hole to drill my 2 1/4" from inside the trailer and then keep going through the exterior metal as well?
Old 03-09-2016, 04:38 AM   #20
Msmoto's Avatar
2007 25' Safari
Images: 135
Drilling through aluminum
I suspect one could do this, but why? I have found drilling up creates issues of the waste potentially falling into eyes, and aluminum dust is a disaster if one gets into an eye, cannot be removed with a magnet as steel filings are.
When measured about three times, checked by a second person, drilling from the top is preferred, IMO. The key is to do this very slowly, using a sharp high quality hole saw designed for drilling thin sheet metal. My technique is to use a hole saw and keep touching and withdrawing, very slow RPM, as once an initial break through is obtained the risk of distortion, drill grabbing, etc., is high. Although I did not do this, taping the inside with several layers of duct tape may be helpful, or have someone hold a thick board up to the inside surface to support it during the cutting process. Using the tape would also tend to catch some of the metal filings.
I think it may be easier to use something to allow a pilot hole in the roof... maybe even a small piece of masonite glued in place.....
AIR #31871 K4MTL
Old 03-16-2016, 09:19 PM   #21
Napking
Skee75's Avatar
Fair enough. Thanks for the insight.
Old 03-27-2016, 07:32 AM   #22
Msmoto's Avatar
2007 25' Safari
Images: 135
Final Curtain Iteration
After working many hours, I have finally arrived at the final iteration of my Serenity Curtains/Blinds, and am actually quite happy with the outcome. The valance matches the rust colored surface in the galley area, so it carries the color across nicely.
Serenity Curtains_Final_03.27.16 by Tommie Lauer, on Flickr
AIR #31871 K4MTL
2015 Serenity Modifications Msmoto 2011 - 2015 International 55 04-21-2018 09:11 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-19-2011 02:00 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-12-2011 01:50 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-05-2011 09:50 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 09:40 AM
