Old 03-24-2014, 10:15 AM   #15
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
Thank you for "Frame"
It's more clear in my mind now, I hope an answer about the fixations wood frame on body frame and when I'll begin to build the wood frame, I'll post photos before to lift the body.
I thougth I knew many things, I underestimated the difficulty but in fact... I have to learn many things !
Thank you for all your advises.
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 03-24-2014, 05:30 PM   #16
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have just placed the shell back on my frame after a great deal of repair work. This is a picture of the gantry I built. My shell was suspended from October 22, 2013 until March 2014 without any problems.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-25-2014, 07:44 AM   #17
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
As to securing the wooden frames to the airstream frame, I used regular screws. I will post a picture shortly. I'll be interested in seeing the condition of the chassis. Hopefully, there will be little frame rust. I used POR-15 with great results.
surfpod is offline   Reply With Quote
Old 03-25-2014, 08:30 AM   #18
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Screws into frame
Here's a picture of the securing screws. I have recently lifted a 1961 Bambi. A bit shorter than yours, but same era. www.lilbambi.net
ID:	208265   Click image for larger version
Old 03-25-2014, 08:48 AM   #19
GaŽl's Avatar
1960 26' Overlander
Images: 8
Hi Craig and Surfpod,
Thank you for picts and I'm rassured now...
Ok I'll use standard screw and squares in order to assemble the wood parts together.
1960 Overlander
Old 04-24-2014, 11:28 AM   #20
GaŽl's Avatar
1960 26' Overlander
Images: 8
This morning, I've tried to remove the panels under the chassis but...it seems I've missed a step...
What I have seen :
The panels under the chassis are fixed between the exterior sheets and on the frame.
What is the way to remove the sheets under the chassis (without to seprate body from chassis because it isn't for now).
Thanks !
1960 Overlander
P30 and C30 chassis questions??? RhinoWW General Motorhome Topics 1 02-18-2014 04:24 PM
Chassis Batteries -- What do you have and why? warrenivan Classic Motorhomes 22 11-13-2011 09:42 PM
Chassis on a 1995 Diesel LY mycall57 Land Yacht/Legacy Motorhomes 4 06-03-2011 10:02 PM
Fuse panel for the moho chassis? WineStream General Motorhome Topics 7 06-01-2011 11:02 AM
Chassis Upgrade? Flying Cloud 30í Sofa Tom_ATL 2009-2015 Flying Cloud 2 05-10-2011 02:36 PM
