Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 04-05-2008, 07:30 AM
DKDarrow
Refurbished 89 Excella
DKDarrow's Avatar
Profile:  Sugar Valley, Georgia
Sensor Panel Help Please
I have an 89 Excella that is close to being near perfect. The only problem that I cannot solve is the sensor panel in the range hood that indicates battery, grey, black, and fresh water levels. It reads the battery level just fine; but when checking the other levels the indicator reads empty no matter what the true level is. If you hold your tongue just right it will just for an instant scan full or perhaps even true.
I researched on here several months ago and a fella was trying to get a line on someone to repair this. The part is unobtainable from the factory, In Land Marine, other dealers, used parts, and other salvage places.
I took the panel off yesterday and it is manufactured by Larson Electronics Mfg, in Fullerton, Ca. Many hours of research found the company who bought them out back in the mid 90's. A tech there informed me that they had no way to repair them and the one guy who used to do this is now overseas.
The electronics is old style transistor, resistor, diodes, capacitors, etc.........Calling to find someone who could troubleshoot these old devices in the Atlanta area has found no one...........I find this really hard to believe. Even someone who could take the little board and directly replace the components without testing them.............
So, yes, I can look down into the tank of the black water from the toilet and judge from that when it needs to be dumped. The grey water, when it begins to back up into the shower needs taking care of. It's the fresh water that has me stumped as to get a reading on. I hate to drag around all of that weight or even worse not to be able to plan booney water replacement needs.
Yes, as the really nice parts lady at Inland suggested I can put a new sensor system in; but I just finished up redoing the bottom skin and really do hate pulling that, the tanks, etc to put in new probes................
What to do?............thanks guys...........Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
Get rid of these ads... register today, it's FREE
Old 04-05-2008, 08:13 AM
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist, at Large
Hi Dennis and Sue!
Looks like you buttoned her up a little premature
It may be the Sensors and NOT the METER!
Sensors are notorious for failing, even the new systems.
Just like gambling folk, some people have the luck, others don't!
Your best bet would be a salvage yard. Most all RV's and trailers used this brand meter/sensor, so it's a good bet that there are a ton floating around out there.
Your tank sensors actually working is another issue
RV Salvage yards
Let us know the outcome.
Best,
Michael
Old 04-05-2008, 08:21 AM
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln, Mississippi
There are re-calibration techniques that you can try so that you can localize it to the sensor or maybe cure your problem. If you do not have the manual - try contacting the manufacturer or search here for other posters who have had this issue. I had read one thread that had the manual in PDF file format scaned in. I will look for it or someone else may know where it is.
Good Luck
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 04-05-2008, 08:25 AM
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Artist, at Large
Eary sensors
Hi Clancy_Boy!
In 1989 it was WYSIWYG.
There were no calibrations, like on your late model unit.
M
Old 04-05-2008, 08:48 AM
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln, Mississippi
Originally Posted by ArtStream
Hi Clancy_Boy!
M
ooopppps - sorry about the bad info, I had to do mine on the 03 CCD when I got here. That's what I was thinking about. Thank You ArtStream.
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 04-05-2008, 03:45 PM
DKDarrow
DKDarrow's Avatar
Actually, I believe there is a way to calibrate them, if mine was working I could tell you. Went back down to the trailer to look at the panel. Each button you push to check the various levels is a rheostat/switch with an adjustment screw on the back. Put a drop of WD-40 on each screw and then screwed them in and out to the stops a few times.............NOTHING......
Pulled the terminal plug off of the end and cleaned the contacts........NOTHING.............
On Monday, I will start calling the salvage places that were posted..........
Thanks Guys.......I keep trying..........God Bless........Dennis
Dennis & Susan
Old 04-06-2008, 11:45 AM
Motoman
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside, California
If you think the switches in the panel are intermittent, i.e. you indicated the panels sometimes indicates, you might get some electronics spray cleaner and spray it in the switches as you work them back and forth. Make sure you buy a cleaner that is made for plastic so it doesn't damage the panel or knobs. Re-calibration of any pot or rheostat may be necessary afterwards.
You can try a Radio Shack but most seem to be just cell phone shops now days, An industrial electronics supplier like Electronics Warehouse would be a good place to look and they might offer some help in selecting a spray electronics cleaner.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Old 04-07-2008, 04:58 AM
DKDarrow
DKDarrow's Avatar
Motorman............Looked and checked and checked yesterday about if the switches are actually intermitent..........THEY ARE NOT..............They just flash all the way across the board as you work the switch in and out........
I used WD40 on the back of the switch; but just a drop......I like your idea about the electronic cleaner. This will allow me to "saturate" the assembly.......
Any ideas about how to check or get a reading on the fresh water level?
Dennis
Dennis & Susan
Old 04-07-2008, 06:08 AM
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay, Rhode Island
Hi Dennis, it was me you spoke with a few months ago. My board has the EXACT same symptoms.
Here is what I found out so far;
  • You are right about Larson, I went through the same exercise. Spent considerable time tracking them down...no luck in replacement/repair.
  • I did speak with an electronics troubleshooting company. When I first approached them last year,they were willing to troubleshoot/rebuild the board for maybe ~$200. I called them back (with you in mind as you said you were interested) and they have changed their tune. Sounds like they have taken on some bigger customers and were not as interested in fixing our boards. They would do it, but wanted to get some minimum amount of boards to make it worthwhile (I don't blame them).
  • I tracked down an identical board (finally) from another member (who had a tree total their AS) they said their system was working fine. I received the board, plugged it in and ???gues what, same symptoms....so...sounds like the problem is elsewhere (which is good news, I think).
  • BTW, I called DOZENS of salvage yards, even had some other members visit salvage yards around the country and could not find a single one of these boards...so good luck trying to find one.
So what's next? As I believe the problem lies in the wiring harness, some where between the board and the tanks, I will get under there AGAIN and look some more. I am convinced it is NOT the board. The weather has been too crappy here to crawl around underneath and troubleshoot this. I hope to get to it this week. I believe it is a commen ground that is the problem, as you have found, battery level is fine, light, fan, etc all work. It is just all 3 tank indicators that quit working. I will post details of what I find and how I fix it soon.
One more option; a simple meter (Radio Shack-mounted inside cabinet?) to monitor fresh water level. As you have noted, I can get around the gray/ black tank levels. Fresh water is critical....
Stay tuned, Bill
Life is Good-Camping all around New England
Old 04-07-2008, 06:40 AM
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs, Florida
Ground problem?
Check the common ground at the sensor panel. I think a high resistance in the ground would cause the problem you describe.
Old 04-07-2008, 09:52 AM
DKDarrow
DKDarrow's Avatar
Hey Bill........and MR. Pop Rivet.............Good to hear from you Bill!!!!
Hmmmm this sounds encouraging about the common ground. Wonder where that might be???..........In the panel wiring???.....You are correct about the battery itself getting readings and lights, fan, etc working, so that would mean that the ground is good there......So would the ground for the sensors be between the panel and the tanks...........???????
The plug on the panel board has bare wires on it would seem each sensor circuit/tank......I assume these are grounds for that particular tank/sensor.......
I need to pull the panel off again and see if I can trace that particular harness/bare ground wires as they leave the panel/board plug......
Getting ready to head out in the trailer for a few days/week or two.....SO PLEASE LET ME KNOW WHAT YOU FIND.......I will be monitoring this..........
THANKS............Dennis
Dennis & Susan
Old 04-07-2008, 10:13 AM
DKDarrow
DKDarrow's Avatar
Susan is packing groceries away in the trailer as I write this so I can't get to removing the panel.........What I will do in a moment or later is:
The plug that attaches to the panel/board is one of those multi plug/wire connectors.........a flat plug with perhaps 12 or so different sockets that slides onto the board connectors........The wiring from the various sensors plugs into the board here.......There are several bare wires, with NO insulation at all on them going into this plug as they come out of the wiring harness..........I plan to use an ohm meter to one of these bare wires to see if there is actually a ground from where ever it is they come from.........If I touch one of these wires with a probe of the ohm meter and then to a common ground, like the light or something else that is there and DO NOT get a reading then that should tell us if the ground theory is correct..........
Then it would be a matter of following that wiring harness back to where it goes to pick up it's ground................
Thanks for the help........will let you know..........Dennis
Dennis & Susan
Old 04-07-2008, 11:04 AM
DKDarrow
DKDarrow's Avatar
Well shucks...........just tested what would seem to be the ground wire for each circuit and they ALL test out as a closed circuit...........A probe of the ohm meter on the gound wire and then over to the ground wire of the water pump..............Continuity on each...........
I am dyslexic, see things backwards sometimes, especially circuits.......Please bear with me........Put the probe on the ground wire and on the other wire of the sensor and got a closed/circuit.........shouldnt I be getting an open, no reading on the ohm meter........that is until the button/swtich is pushed which closes the circuit?????
And no......I still do NOT believe it is the sensors themselves because for all 3 of them to fail defies coincedence..................thoughts?????
Dennis & Susan
Old 04-07-2008, 11:05 AM
DKDarrow
DKDarrow's Avatar
Bill..........what kind of meter are you refering to about the fresh water level......would it use the existing sensors?????
Dennis & Susan
vB code is On
Pingbacks are On
Low Coolant Sensor guy99 General Motorhome Topics 25 04-26-2006 06:12 PM
Water tank Sensor locations..... leefields Plumbing - Systems & Fixtures 1 02-17-2006 11:16 AM
Shurflow 5.7 with chip sensor JimmyJames Water Heaters, Filters & Pumps 5 11-25-2005 06:08 AM
Oil pressure sensor on 454?? WYScott Mechanics Corner - Engines, Transmission & More... 15 10-09-2005 09:21 AM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 06:04 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
