Dennis, if I understand system correctly, your tank (s) would need to be full to return a voltage.
Fill up your fresh and see what you get.
Yes, any gauge/meter that reads within the same voltage (12v) as the camper should work. I had the exact voltage returned from the sensors at one point but can't remember now (CRS disease) but I believe it was in the owners manual. I was planning on using the stock sensorsIF the panel was garbage. Now that I am fairly convinced it is NOT the panel I am going to invest more time doing what you are doing at this moment; tracing back all the gorunds (it MUST be a common ground) and finding the bugger.
Like you, all 3 of my tanks quit at once. Worked one week, next week they were blotto...
Let me know what you find, I won't get to it until later this week.
Bill
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
you might try looking for on old tv technician or advanced ham radio type. they might have the know how to check out some of the board components. i once knew someone that could repair almost anything on a board.
i agree that for all of them to fail at once seems to indicate something all those guages have in common. a bad power source connection might feed a bit of voltage until the current draw forces the circuit to fail as with a bad connection at a splice or fuse.
happy hunting!
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
I have never seen a board that worked properly. It is my humble opinion that the purpose of the lights is to look pretty and impressive to someone that doesn't know any better. they didn't work properly on my 94 nor do they work properly on my 2001. They are not horribly off but I know as much from how long I have been out as to the status of my tanks, battery, and propane as the indicator lights tell me.
Keep the shiny side up. WBCCI # 3485 Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @ www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Thanks Guys...........Does anyone have an idea as to exactly where the sensor panel/tank sensors actually pick up their power?............Must be at the fuse panel at the power supply????????
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
Be sure to check the solder joints around the plug on the board. These areas can break loose and cause a bad connection. Resolder them and maybe this will help.
Well I have checked everything I could find/see. Even tried the other board from salvaged AS that PO said was working fine.
Symptoms are the same with both boards, so it MUST be in the harness?
Catastrophic/sudden failure or all 3 tanks at once, and ONLY the tank gauges (battery/lights/etc work fine) all 3 tanks read "E" only.
What connection do all 3 tank sensors have in common?
Any ideas?
Thanx, Bill
Hey Folks.........just got back from 2 weeks of video editing/relaxin/rest..........
Early in this thread I talked about putting a few drops of WD-40 on the adjuster screw for each switch/rheostat and then working the screw in and out a few times............No results I thought.......A few days later the grey water began to register 1/2 full, when full and the black was 3/4 when full................These had not worked for 2 seasons...........
A few days later decided to fill up the fresh water tank as the grey and black were both full again.....................IT WAS WORKING.........
Pulled the panel apart again...........a few more drops of WD 40 on each screw, let set overnight and am able to get a full reading on each..........Calibrated them and YES they are working..........
God is so very good to me.................Dennis
Dennis & Susan
Yes, I also tried Dennis' fix last week, but it was clear my gauge failure was of a different nature...
I believe I made a break through last night and will document the entire fix and post in a week or so...
Bill
This post details the process to repair to my once working monitor panel; let me define what happened. As we have been doing an increasing amount of boon docking, the ability to monitor fresh, particularly, becomes critical. If you camp with hookups, you can easily get by with out gauges.
If your failure mode is similar,and your system is of the same vintage (80’s-90’s) you may benefit from this troubleshooting and repair process.
The system uses a board manufactured by Larson Electronics ; board should be labeled on the back, which utilizes foil pads on the tanks. From what I have found, this system was used by AS in the 1980’s until about mid 90’s. A voltage is passed to the tanks, and based on the amount of fluid in the tanks contacting the foil pads (resistance) a voltage is returned to the gauge panel, resulting in a certain number of LED’s illuminating indicating the fluid level in your tank (s).
Failure mode, in our case, was catastrophic; one day all gauges were working, the next day all three tanks (Fresh-Black-Grey) would only return a reading of “E.” All other functions controlled by the monitor panel (fan/light/battery level) continued to function. The manual outlines several causes for gauge readings of “E”; lost connection at foil pads on tank, bad board, and bad wire, lost ground, etc. It is my understanding that several other Folks have had this exact same failure, so this may be a very typical failure mode.
Some of these conditions would be easy to diagnose; I had ground, it was unlikely the foil on all 3 tanks came loose at the same time (camper had not moved since this happened). After checking all the obvious, I began to dig deeper and started to think that it was the board that failed. I pulled the board and diagnosed at board level. I found one proprietary chip that I began to think was faulty. AS said they no longer stocked this board or any components. Then I tried to contact Larson, which has since been sold/bought 3 times. No one there had any real history with this board, it is no longer manufactured, and there was no willingness to diagnose. I then contacted a Tech house which offered to diagnose and rebuild the board at some cost. They did infer that it would be more cost effective to gather several boards to send in for repair. I contacted some other members and started to consider doing this. After some time passed, I contacted the Tech house again and they said their business was ramping up and they sounded a little reluctant to take on this project (understandable). Meanwhile I have been scouring every Salvage yard, internet site, other members looking for another board. One year later, I hear from a member that (most unfortunately) has a tree fall on their early 90’s AS and is parting out. They say their monitor panel was working fine, and yes it is a Larson. One paypal and a few days later my new board arrives (still winter here in New England); I rush outside and plug in the board-Eureka!? Nope, same failure mode, tanks only read “E.” Disheartened, but not discouraged, I reassess my attack; it must be in the harness.
The next step is to begin working through the harness at the board connection, using the schematic in my manual it soon becomes clear that the problem is in the blue wire (fresh) red side (positive return from tank) which supplies power to all 3 tanks! As the only exposed wire is maybe 12” or so at the board and under the range hood, and the bulk of it runs inside the wall, that left only what is in the belly of the beast. Now what? Drop the pan? (This as you know is a big project; jack up, support, drop the pan, fix it, reassemble). I call AS again and they say there should be access through the wardrobe near the water pump…well…maybe a 6” hole, but it is not enough to see anything. I also asked if there were any common connection for the tanks in the belly and they reply that no, all 3 tanks are wired independently. This does not make sense to me as all 3 tank gauges failed at once and I am sure they share some common connection. I start to poke around underneath and soon find myself near the dump valve. I pull away some silicone sealant and look inside with a flashlight…what is that? The blue wire? Can’t be I am on the opposite side-why would the wires run all the way over here. I reach in and grab the wire; there is sufficient slack to pull it out through the small hole I exposed adjacent to the dump valve.
What do I find? A severely corroded harness with the same 12 leads that are found at the board. After snipping off the end and stripping back the insulation, I bypass the tank and yes! We have return voltage! So I mark off all 12 wires (so as not to get confused between voltage out and return) purchase some high quality butt connectors and liquid electrical tape (this is not a job you want to repeat often) and wire everything back together. Be sure to follow the schematic; blue wire red insulation to blue wire red insulation, clear to clear, etc. It took an entire year, but now I have my gauges back and Life is Good!
Summary; if you have this system, and you have had this failure mode (sudden failure of tank (s) gauges, no reading, or only “E”) then this repair may be worth your time. Maybe I got lucky, but I would start by peeking around the dump valve/pipe and look inside for the blue wire and associated harness. Maybe you can have working gauges again too! If anyone has any questions or needs more details, please contact me.
Bill
Reason: add pics
I have an 1989 Excella. The control panel has a switch labelled "Auto-Fill", I cannot find any info in the manual that refers to this. Does anyone else have this on their control panel? If you do what does it do.
