Pulled into our site for the weekend and noticed that the seelevel 2 monitor is dead! No digital display readout. Pump light comes on. But no display. I've checked the breakers... all good. I am not sure where it draws power. All outlets in the trailer have power.
Anyone have ideas as to what I can check?
Confused for sure. As far as I can tell, everything else in the trailer is up and functional.
The sea level monitor runs off your 12v system. Check all the fuses in the power panel for 12v.
Ours went out in a nasty power surge (along with a bunch of other 12v control devices). You can purchase a replacement control panel if need be and it's an easy swap out.
Hope this helps.
Thank you for the advice! My 12v panel is labeled from the factory and it doesn't list the seelevel so it's not obvious which fuse it is. I'll snoop around.
Saw the title of this this thread and my first thought was 2 people had died somewhere at sea level. It would make and excellant headline hook in today's shady news.
MICHAEL
Unfortunately, it wasn't as obvious as a dead fuse. They are all good in the panel... unless there is another bank of uses hidden somewhere in the trailer. I guess it's possible that the display is zapped.
