Old 11-02-2016, 07:46 PM   #1
1993 34' Excella
see-level tank monitor NEEDED
While gutting my '93 Excella, I was not thinking clearly and threw out the see-level tank monitor. Unfortunately, the new monitor isn't compatible with the existing sensors in the tanks. New subfloor and floors are installed. Any ideas of where to find an older one? I've tried eBay and the airstream classifieds.
Any info would be fantastic.
thanks!
Nan
NJB1972 is offline   Reply With Quote
Old 11-02-2016, 08:10 PM   #2
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
Is this the monitor that's built into the range hood?
cliffcharb is offline   Reply With Quote
Old 11-03-2016, 06:01 AM   #3
1993 34' Excella
Yes. It was built in. Don't even know if it could have been removed. I was having way too much fun with the sledge hammer.
Old 11-03-2016, 07:09 AM   #4
The Myth
Killeen , Texas
Is it this one?
http://airstreamsupply.com/80s-airst...search=monitor
JPAS is offline   Reply With Quote
Old 11-03-2016, 10:16 AM   #5
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
I gutted a 95 limited years ago and kept a lot of items I thought I would use one day. I'll check tonight and if I have that panel it's yours.
Old 11-03-2016, 11:03 AM   #6
1993 34' Excella
It was actually a part of the range hood...but that one may work. If Cliff doesn't have one,I will certainly try that one. Thanks. Any idea what year it is?
Old 11-03-2016, 01:23 PM   #7
losfeliz's Avatar
1981 31' Excella II
Florence , Alabama
It looks identical to the one in my '81 Excella II, up above the microwave/refrigerator cabinets. If you want a picture I can get one for you tomorrow.
losfeliz is offline   Reply With Quote
Old 11-03-2016, 01:38 PM   #8
The Myth
Killeen , Texas
Im not sure. It just says "'80's" on the ad. Possibly someone else here can confirm it to be the correct one. I couldn't find an entire hood unit(not sure if you need the whole thing) but there are still other vents available with the monitor built in.
Old 11-03-2016, 02:59 PM   #9
1993 34' Excella
That would be awesome! Thank you.
Old 11-03-2016, 03:06 PM   #10
1993 34' Excella
Thanks so much, that's probably gonna be the way to go, without having to do major surgery on the new floors. Lesson learned!
Old 11-03-2016, 06:58 PM   #11
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
Sorry, no luck finding it. I must have tossed it. The link posted is almost the same as my 81 Excella so I doubt that would work.
2016 Classic Water Tanks and See Level II Monitor jeff4506 2016 - Current Classic (all lengths) 21 07-02-2016 01:00 PM
See Level tank monitors dznf0g Waste Systems, Tanks & Totes 0 07-02-2014 09:21 AM
Help on removing tank level monitor panel Ditter Waste Systems, Tanks & Totes 1 02-18-2014 12:44 PM
Tank level monitor suggestions for new black/gray tank redreefet Waste Systems, Tanks & Totes 5 06-28-2012 07:39 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 04:52 PM
