Old 04-10-2014, 06:18 PM   #1
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
Seam sealant
Has anybody ever used osi micro gutter sealant for a seam sealer ?
teebs32 is offline   Reply With Quote
Old 04-10-2014, 06:27 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
No, but I've used PARBOND for thirty years on four Airstreams.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-10-2014, 06:44 PM   #3
teebs32's Avatar
1977 31' Sovereign
mansfield , Ohio
How often did you need to reseal entire unit and about how many tubes . They are only 5 oz. If I'm not mistaking. I'm going to reseal a 31' .
Old 04-10-2014, 08:00 PM   #4
Mike Leary's Avatar
Images: 11
I had thought they made caulk-sized tubes, but the little ones sure are accurate and clean.
Seam Leaks: caulk or sealant? Chillbilly General Repair Forum 32 03-24-2015 09:24 PM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
Recommended External Seam Sealant Ron Schroer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 11-12-2010 04:44 AM
Painted Argosy seam sealant-after the fact? maxandgeorgia Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 06-14-2010 07:35 AM
