Old 11-10-2013, 07:46 AM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
So how much does a pump for Vulkem go for? I assume it can be used for other materials too?
Old 11-10-2013, 09:02 PM   #16
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The pump is not cheap - I recall it being around $20 (guess). There are two variations of the pump - one actually screws on in place of the lid on the tin of Vulkem, the other, which I have, has its own canister. In terms of shape, both are the same shape and size. Vulkem never dries hard, so the pump I loaded when I was at JC (they use the stuff in bulk and were kind enough to just load my pump at the same price) 2 years ago still flows when pumped. The key thing is that it lays a very small bead - about 1/16". As was mentioned before, expect to be surprised where you get it on your clothes!
Don't expect to use it on other materials, though. You will find it quite a chore to clean out the pump.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-10-2013, 09:08 PM   #17
reinergirl's Avatar
Hollis , New Hampshire
What? I don't know of a pump for Vulkem? There is one for Acryl r... Which I have and have never gotten to work .
reinergirl is offline   Reply With Quote
Old 11-10-2013, 10:51 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There may have been some bad pumps...but they are a "must have" for applying the Acryl-R... Just did a few feet today where I discovered a problem. No need to wait until "next season"... Deal with each problem ASAP. They stay little problems, usually.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-12-2013, 07:09 AM   #19
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
From the Airstream store: https://store.airstream.com/product_info.php?products_id=163
Price is $48 including a can of Vulkem.
VE3JDZ
AIR 12148
Old 11-12-2013, 07:20 AM   #20
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Originally Posted by blkmagikca View Post
I thought Vulkem was similar to Sikaflex, not Acryl-R. I thought Airstream was using Sikaflex instead of Vulkem in recent years.
I used Parbond as a substitute for Acryl-R to avoid the expense of buying the pump. I bought the Parbond from Out of Doors Mart. Good video on the ODM website on the application of Parbond. I have been happy with the Parbond after two years in use.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 11-12-2013, 07:28 AM   #21
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'm no expert on sealants, Bud. I just go with what JC says. Vulkem is a brand of sealant, but other brands may have the same composition and properties. As I mentioned, I bought the stuff at JC where I have my regular servicing done.
VE3JDZ
AIR 12148
Old 11-12-2013, 07:29 AM   #22
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
So that applicator is specifically for the ACRYL- r and comes with the can of ACYRL- r product. Vulkem which is now call Trempro 635 or 636 is a different product and is only sold in a caulking tube that I've seen.
They seal seams very well but are different types of sealant, FYI.
28430W-100ACRYL-R 16 OZ CAN WITH APPLICATOR
desertair27 is offline   Reply With Quote
Old 11-12-2013, 01:16 PM   #23
blickcd's Avatar
Milford , Ohio
I'm really surprised that no one asked yet, but Chillbilly, where are you seeing water get in? Front window area, coming from a seam in the wall panels? Any more information would help and we could advise you where to apply the sealant of your choice.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 11-12-2013, 04:56 PM   #24
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
If you look back at my earlier posting (post #8 of this thread), I mentioned that the pump I got was from the Hardware store near the factory. That pump has a 1-piece canister that screws onto the pump - it is, consequently, brand/manufacturer neutral. It is the pump that they actually use at JC, as they buy the sealant in drums. When I bought the pump at the hardware store, I took it over to the factory and they filled it for me (small charge, don't remember how much it was).
VE3JDZ
AIR 12148
Old 11-12-2013, 07:49 PM   #25
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Well that's makes total sense, I'll have to try the trempro in that type of applicator.
Thanks for the info.
Mike
Old 11-12-2013, 09:15 PM   #26
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A few weeks ago at the factory tour they were using Adseal and another sealant for finer applications I didn't recognize the name of.
Doug and Cheryl
Old 11-14-2013, 03:57 PM   #27
East Tawas , Michigan
As woodfox 45 stated Capt. Tolley's is great stuff. I used it to detect leaks on horizontal lap joints on my AS roof seams. It will wick into a leak area like magic, give it as many coats as it takes to seal it (usually two or three). I am convinced.
baylito99 is offline   Reply With Quote
Old 11-26-2013, 11:56 AM   #28
1970 27' Overlander
1989 32' Excella
Bay City , Texas
I have a leak problem from the over head strip up forward where strip ends and under each window above bunks. Replaced AC not long ago but ruled that out as source of leak.It seems it would have to be close to centerline on roof but can't locate where. any suggestions appreciated. On caulking products, I've used 3-M 5200 marine caulk on my boats for many years.
capt ken is offline   Reply With Quote
removing white roof sealant? blackhawksid Roof 3 10-13-2011 10:48 AM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
HELP! kitchen window leaks Jcashcollect Windows & Screens 4 06-23-2011 10:41 AM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
