Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 03-20-2016, 07:58 PM   #1
2013 27' FB International
Enterprise , Alabama
Seam leakage/drippage
I have a 27fb international and have noticed that the seams where the front section connects to the mid section seems to have water run down the seam from top to bottom. It corresponds with where the awning ends and water runs down the exterior of the trainer from general rain water or the a/c. Has anybody else had this experience and if so what did you do about it. ?
dneff01 is offline   Reply With Quote
Old 03-20-2016, 08:10 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If not raining , it has to be from the ac unit which is susposed to drain down the drain tube to maybe the wheelwell, maybe the line is plugged...
Old 03-20-2016, 08:13 PM   #3
It seems to be that water runs down that seam on the exterior of the trailer which some then finds itself inside. Trying to figure out if maybe some calling could be needed somewhere
Old 03-20-2016, 09:13 PM   #4
Mixter's Avatar
1976 27' Overlander
Yep. I am in the middle of a shell off restoration and I found exactly what you describe as a manufacturing defect. They do not seal the lap seam- except to slather on vulkem on the inside AFTER its put together.
Water finds a way....
The awning rail becomes a gutter. Water flows like a river down that seam. It was making its way in SOMEWHERE and I couldnt find it. First I drilled out 1 window and resealed.... then I did another... then I drilled out the top of that seam and injected sealant before re-riveting... then I did the middle of the seam.... eventually I had drilled out and re-sealed the entire seam and now I have no leaks there.
Now when I see pictures of damaged flooring in peoples Airstreams, I find this to be a common rot point in the same places on the floors....
Mixter is offline   Reply With Quote
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Window leakage on 1975 Sovereign 31' Airstream ebrannen General Repair Forum 4 10-08-2012 06:46 PM
Antifreeze leakage peck1937 Mechanics Corner - Engines, Transmission & More... 3 01-01-2008 12:26 PM
Mystery Black Water Tank Leakage Howard Lefkowitz Classic Motorhomes 2 06-06-2006 02:54 PM
Battery leakage ???? Kistler Our Community 1 05-09-2003 04:17 PM
