Old 08-05-2014, 04:58 PM   #1
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
Sealing - question re: Plews Lubricant-matic Pump
I got this lubri-matic pump from Airstream as part of a sealer kit. I've seen them, once attached on a can of sika-flex sealer, but how do you get that spring in? Looks like it goes in the bottom of the pump assembly (at left) and then in the bottom, at right, with the pin (held at the top by the handle) holding it all together. But I cannot get that spring to compress enough to attach the pin - heck, not even enough to slide the bottom barrel over the top. It can't be this difficult.
What am I missing?
Name:	ImageUploadedByAirstream Forums1407279508.980871.jpg
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
Old 08-05-2014, 09:07 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My pump came assembled. Looks like yours is defective. I can't imagine why it is apart.
The "pin" goes I to the end of the nozzle to help seal from evaporation of the solvent. Putting the whole thing in a ziplock bag also helps a lot.
I would ask AS to send you a functional pump.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-05-2014, 09:58 PM   #3
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
Thanks. That is good info. Mine came in the pieces you see, in the box, loose as you see. And I should have been more clear.
I was referring to the "pin" that is actually a long lever that runs from the handle down through the black housing and hooks into ths bottom barrel. It holds too and bottom together and with the handle actuates the pumping action.
I was hoping to avoid sending it back but giving them a call is a good idea. I'm sure whoever fills orders won't have a clue. My fear is they exchange it... With another box of the component parts!
WBCCI 1054
VAC
TAC
TCT
Old 08-06-2014, 06:40 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
It is rare you had that happen.. I would give them a chance to make it right.
Channing
WBCCI# 30676
Old 08-06-2014, 09:09 AM   #5
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
Thanks Carly!
Just got off the phone with "Carly" from Airstream customer service, who said it should have arrived only having to screw in the nozzle. (And my apologies for assuming they wouldn't "have a clue.") They will send one out today, with a "call tag" for me to return the other one.
You were right - Airstream wanted to "make it right."
Thanks, Channing... you work here is done!
(now, off to the Vintage rally in Wenatchee for me...)
WBCCI 1054
VAC
TAC
TCT
Old 08-13-2014, 02:35 PM   #6
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
A follow-up: first, it was 'Amy' at Airstream, not who I thought above, who deserves the thanks. Second, below is what this expensive pump SHOULD look like, out of the box. Note. The spring that bedeviled me attaches around the pump link (what I first called a pin) that attaches to the handle and the pump bottom.
Thanks too, to all who posted advice. Click image for larger version
Name:	ImageUploadedByAirstream Forums1407961966.968909.jpg
WBCCI 1054
VAC
TAC
TCT
Acryl-R Plews pump NOT Silver Otter Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 07-28-2012 09:08 PM
Lubricant 1953 Flying Stoves, Ovens & Microwaves 1 06-29-2007 03:00 PM
h20 compresser lubricant Flyincloud Water Heaters, Filters & Pumps 3 08-23-2004 06:25 AM
Door hinge lubricant paddy79 Doors & Locks 2 07-27-2004 08:45 PM
coconut oil lubricant for drains murphy Waste Systems, Tanks & Totes 9 05-12-2003 08:01 AM
