Old 08-26-2016, 12:30 AM   #1
2016 26' Flying Cloud
Southlake , Texas
Sealing hole in floor in 26u
I was cleaning out the compartment where the inverter, subwoofer and other miscellaneous items are located under the dinette. I noticed that I can see the ground when looking through the hole in the floor where several wires go underneath the trailer. What can I use to seal the hole that will be easy to get out if I ever need to run a wire through the hole. I first thought of silicone or spray foam insulation but those are both tough to deal with if you need to run something else through the hole. It doesn't look like any attempt was made to seal the hole by AS.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 08-26-2016, 06:40 AM   #2
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
As new as your Airstream is, I wonder if you shouldn't be taking it in for a warranty claim to get the hole repaired?
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-26-2016, 07:08 AM   #3
kswelsh's Avatar
2006 30' Classic
Wildwood , Missouri
I agree, take it back to the dealer. If you can see the ground, the mice can see in.
kswelsh is offline   Reply With Quote
Old 08-26-2016, 07:27 AM   #4
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Just seal hole with great stuff foam. That's all the dealer is going to do. Save yourself the hassle of trying to get it into a dealership.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 08-26-2016, 08:16 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use silver metal HVAC tape to close off holes as I find them.
MICHAEL
Old 08-26-2016, 08:44 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Butyl tape works well. You can fill the hole and it will stay pliable.
2012 Dodge Durango Hemi/AWD
Old 08-26-2016, 09:41 AM   #7
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
Great Foam with Click image for larger version
Name:	ImageUploadedByAirstream Forums1472222488.538086.jpg
ID:	270047pest control. It's amazing all the holes in an airstream that critter can get through.
Kemblkr is offline   Reply With Quote
Old 08-26-2016, 01:47 PM   #8
LilBigfoot's Avatar
London , Ontario
Same hole on my 26U. No big deal! I just stuffed some stainless steel wool [scouring pad] around the wires to fill the gaps.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 08-26-2016, 02:30 PM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
00 (double aught) steel wool...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-26-2016, 04:19 PM   #10
2007 22' International CCD
Regular steel wool will turn into total rust in no time. Go with stainless...
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 08-26-2016, 09:30 PM   #11
Southlake , Texas
I went the easy route and used spray foam. I just hope I don't need to dig it out in the future. I know that mice like to eat the foam so I put a bait station in the compartment and will check it from time to time.
Equalizer Hitch
Southlake, TX
WBCCI
Old 08-26-2016, 09:49 PM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
For those using steel wool, remember steel is a great conductor of electricity, and y'all are packing it around electrical wires. Just sayin'...
Old 08-27-2016, 09:02 AM   #13
Punta Gorda, Florida , Florida
Sealing hole in floor 26u
I'm a newbe to travel to tin can living. I have a 2016 FC 26u and your post got my attention. I thought the inverter was part of the electrical panel on the floor opposite the bath room. My dinette area has no openings where I could look into. I'm confused.
Silver Pony is offline   Reply With Quote
Old 08-27-2016, 10:27 PM   #14
Kemblkr's Avatar
The converter is the bottom part of your power panel. There located various place depending on model and layout.
2016 Flying Cloud 26U TG2500 2016 - Current Flying Cloud 400 Today 10:23 AM
26U Macerator Toilet - What do you think? Plan-B Sinks, Showers & Toilets 39 07-12-2017 04:07 PM
A/C problem in new 26u Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-25-2016 03:27 PM
New 2016 26u Trees01 Member Introductions 1 01-17-2016 11:01 PM
26U Floorplan is Sweet! Bewell Airstream Lifestyle 1 09-25-2015 07:30 PM
