Old 04-26-2014, 12:09 PM   #1
2004 16' International CCD
Chicagoland , Illinois
Smile Screwing My Bambi?
I'm wondering how you fasten items to the interior walls of your AS trailers so that the items are secure enough to withstand towing. I'm thinking of items like coat hangers, clock, pictures, maybe a shelf, etc..
I'm sure that using sheet-metal screws would work for heavier items, but would the screws stay tight? Would anyone do this? Or am I thinking crazy thoughts? What length should I use to insure that I don't puncture the exterior? Any hidden locations that I need to make sure that I steer clear of?
I've seen posts where owners have used Velcro for this task. Any suggestions on what type? Tips or tricks?
What other methods do you use to fasten items to your interior walls?
Airrogant is offline   Reply With Quote
Old 04-26-2014, 12:19 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
3M automotive trim adhesive.
It is like double sided foam tape bur stronger and can be removed. I also use Velcro for things that need to be frequently removed... clicks, weather stations, etc...
I personally would never use screws
AtomicNo13 is online now   Reply With Quote
Old 04-26-2014, 12:28 PM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
No need to drill unless it is a permanent fixture or really heavy. I got some of these for my clock and the few items I have and they work really well. The picture is not the exact one I have but there are different ones at Home Depot that even list up to so many pounds, etc. They actually lock together. I have used screws for my router and installed items but not nicknack items. A shelf, probably screws. I just finished installing those ocean air blinds and screwed them in place but that is more a requirement.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 04-26-2014, 06:03 PM   #4
dznf0g's Avatar
Oswego , Illinois
X2 on Command strips. Has worked for me with even framed pics. There are different weight capacities available. They even make the coat hooks...plastic, chrome, etc.
-Rich-
Old 04-30-2014, 01:01 AM   #5
Thank you very much to each of you for the great suggestions. I'm going to get some samples of both products to play with.
It looks like I won't have to screw Bambi after all.
Old 04-30-2014, 08:40 AM   #6
dznf0g's Avatar
Oswego , Illinois
Does your Excella have mouse fur on the walls? If so, attaching the hook side of the "industrial" version of Velcro to your items attaches stuff firmly to the mouse fur.
-Rich-
Screwing into fiberglass bath ceiling? SummitAir Sinks, Showers & Toilets 4 10-22-2008 11:16 AM
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 07:02 PM
Screwing into walls? starflyte1 General Interior Topics 2 03-19-2007 06:33 AM
BAL jack, nut keeps un-screwing Kistler Jacks, Stabilizers, Lifting and Leveling 7 06-08-2006 10:07 PM
CCD International 19 Bambi vs Safari Bambi vajeep 1997 - 2004 Bambi 8 10-02-2003 04:16 PM
