Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-02-2014, 06:45 AM   #1
tenrsingr's Avatar
Screw replacement alloy?
Removing my rub rail with numerous rusted philips head screws leaves me cranky and frustrated. Is there a problem with using stainless screws? I havent seen this subject anywhere in the forum and have been searching. I have had small success removing rusted screws and dont want to have this problem again.
So, can i use stainless? Thanks!
Steve_in_Savannah
'94. 29' Excella Classic
2001 5.4L Ford F150 Lariat Super Cab
wife & 2 boys
tenrsingr is offline   Reply With Quote
Old 09-02-2014, 06:51 AM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I wouldn't see any problem in using stainless - unless someone else comes back with a good reason not to, that is what I would do. I have done that on other trailers.
Were you able to get all the old rusted screws out with a screwdriver or did you have to resort to other means?
I am just about to replace some clearance lights that are leaking and have bald rusted sockets. I am not sure yet if they are mounted with rivets or screws. If screws, I'll bet they will be a rusty mess and I will be replacing with stainless.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-02-2014, 06:53 AM   #3
dznf0g's Avatar
Oswego , Illinois
I go back with stainless or aluminum on every maintenance job I do. Stainless is relatively close to aluminum on that Galvanic reaction scale (some engineer will have to tell the real name!). Much closer than regular steel.
-Rich-
Old 09-02-2014, 07:09 AM   #4
Southwestern , Ohio
I always replace rusty original equipment screws with stainless steel. At the price, I don't know why Airstream doesn't use stainless steel in the first place.
Nuvite-F is offline   Reply With Quote
Old 09-02-2014, 07:10 AM   #5
tenrsingr's Avatar
Not every one. I had to drill out two and the other two I quit on. It was late last night and was tired of sweating. Savannah heat and humidity... Since I had the interior skin off i was able to get to a majority with the pliers to turn loose.
Steve_in_Savannah
wife & 2 boys
Old 09-02-2014, 07:12 AM   #6
tenrsingr's Avatar
Makes me wonder if it has to do with sheering off due to stress. I think the hardness of the ones used allow for some stretching, but if you get any moisture... Rust.
Steve_in_Savannah
wife & 2 boys
Old 09-02-2014, 08:17 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
No reason to over think this. Use stainless.
MICHAEL
Old 09-02-2014, 08:35 AM   #8
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Yes, replace with stainless.
To make it easier to remove the rusted screws use a new screwdriver, place in position on the screw, whack the screwdriver with a hammer several times fairly hard (but not hard enough to deform the aluminum). This seems to break the rust "seal" and sets the screwdriver deeper in the screw. Won't work on all of 'em, but sure improves the odds.
Sam
samb is offline   Reply With Quote
Old 09-02-2014, 08:42 AM   #9
tenrsingr's Avatar
I whacked mine and thats how i got two out, six from inside, two sheared off and two that remain... i grow weary of this restoration process when i bump into this kind of stuff. Family demands make it fairly impossible to accomplish during daylight hours which leaves me only night.
Steve_in_Savannah
wife & 2 boys
Old 09-02-2014, 08:45 AM   #10
Kevin245's Avatar
Stainless is a suitable replacement in this instance.
William C. Swinney
Old 09-02-2014, 09:22 PM   #11
tenrsingr's Avatar
Screws removed!!
Using a hammer and chisel to start the rotation i freed the rest. Now to complete my floor repairs! POR 15, new floor, new STAINLESS STEEL bolts and nuts. Thank goodness the iron frame is still looking good in most of the areas. lots of holes to plug though... no wonder why the floor rotted. find a lot of holes under the the rail.
Steve_in_Savannah
wife & 2 boys
Old 09-03-2014, 09:34 PM   #12
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Here you go guys: stainless for everything unless an aluminum rivet will do. Dab each screw with this prior to inserting and tightening. It is messy, but stops corrosion, thus you will always be able to remove later.
Name:	ImageUploadedByAirstream Forums1409801543.709520.jpg
Used for aluminum/stainless in the salt water marine environment all the time.
Howard L. is offline   Reply With Quote
Old 09-03-2014, 10:10 PM   #13
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Yep, stainless all the way, I even use them on the inside. I now use aluminum rivets on the outside when possible instead of screws. The drill out easy enough.
Silverflames is offline   Reply With Quote
alloy wheel center cap corrosion wmarsha Wheels, Hubs & Bearings 1 10-22-2009 07:08 PM
Are airstream made with through clad alloy got polish Cleaning, Stripping & Polishing 3 08-27-2008 10:31 PM
alloy? Valhala Ribs, Skins & Rivets 3 09-14-2007 04:56 PM
1963 alloy thickness silvermoon Ribs, Skins & Rivets 4 10-25-2005 07:37 PM
alloy wheels T&R Wheels, Hubs & Bearings 3 05-19-2003 06:52 PM
