Old 03-13-2015, 07:29 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Screw or Rivet the Fantastic Fan Vent Cover?
I am contemplating adding a Fantastic Fan vent cover over my bathroom vent because I have kids, it does not have a rain sensor, and of course I am afraid it will be left open in the rain.
The install calls for what appears to be 4 self-tapping screws. So my questions is, because this is an Airstream, do I rivet it? It makes sense to me...I kind of feel I'll be doing a great injustice with screws because the brand is all about rivets.
Ted S. is offline   Reply With Quote
Old 03-13-2015, 07:39 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
If it interests you I believe there are upgrades that will add a rain sensor to you current fan. A google search will find numerous sources, but I'd suggest calling FF.
Since fantastic fans themselves are put in with screws, I think you're okay with using screws !
By all means a rivet could be used, Olympics are okay, or you could used a closed end pop rivet, either way I'd use a sealant on top.
reinergirl is offline   Reply With Quote
Old 03-13-2015, 08:43 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine is screwed in with about a gallon of sealant slopped all around the base.
MICHAEL
Old 03-13-2015, 09:13 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Look at the Maxx Fan. You won't need a rain sensor OR an ugly cover to be able to use the fan in the rain. They work very well and even have a hand held remote with 10 speeds and temperature settings for thermostatic control.
When not in use, it is virtually flat to the roof. The bug screen comes off with the twist of 4 retainers, not the 10 screws that you need to remove with the F/F.
Check it out!
Old 03-13-2015, 09:53 PM   #5
RonaldC303's Avatar
Washington , Utah
The FF cover is a very easy install. You remove four of the existing screws and secure the mounting brackets with four new replacement screws. The cover then clips to the mounting brackets. You will need some sealant for the screw holes and for the top of the screws.
Good luck.
Ron
RonaldC303 is offline   Reply With Quote
Old 03-13-2015, 09:56 PM   #6
laducky's Avatar
1978 28' Ambassador
Pacifica , California
I used the screws with my install but covered those in caulk as well. Besides, I don't think you'll have any rivet inspectors on the roof
Name:	2014-09-25 17.26.45.jpg
Keep on truckin!
airstreamcalledtrouble.blogspot.com
laducky is offline   Reply With Quote
Old 03-14-2015, 07:19 AM   #7
Jarrod White's Avatar
1966 28' Ambassador
Mobile , Alabama
If you're talking about just a cover that goes on top of your existing vent cover, the ones I have seen mount to brackets which are screwed into the side of the vent. This means no holes in roof and no need to worry about sealant or leaks. They take about 10 minutes to install, work well and can be removed without anyone knowing one had been installed and no worry of future leaks. Downside is that while installed they stick up 10-12 inches above existing vent but I personally think they look fine. And to answer your original question, I think screw attachment works fine.
Jarrod White is offline   Reply With Quote
Old 03-14-2015, 07:57 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't think screws vs rivets matters much. They just hold it in place for the caulk. I used Tempro Vulkem. Don't use silicon. and use caulk instead of the foam gasket that comes with the fan.
Old 03-14-2015, 04:24 PM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
JC uses screws to crack the plastic FF vent flange & covers.
Use care when tightening......by HAND.
I didn't use rivet's...inconsistent tightening, no control.
Old 03-14-2015, 04:50 PM   #10
batman's Avatar
1964 22' Safari
modesto , California
"I didn't use rivet's...inconsistent tightening, no control.
Bob"
I agree with Mr. Cross.
I used SS screws and plenty of Trempro, urethane sealant
and mineral spirits to clean up.
-Dennis
batman is offline   Reply With Quote
Old 03-14-2015, 05:00 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
Given the above 2 posts I take back my post about rivets being OK.
Old 03-14-2015, 05:13 PM   #12
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I'd use screws and tighten carefully. Then cover the edge of the frame with Eternabond Alumibond.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 03-14-2015, 05:52 PM   #13
DFlores's Avatar
1968 22' Safari
Pan head Stainless Steel screws. The holes in the Fantastic Fan are counter sunk, if you rivet and do not oversize the head, the rivet will grab less of the FF lip than the screw will, and yes Tempro and blue tape for clean lines, plus WD 40 to smooth it out and give you a finish you will be proud of.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 03-14-2015, 07:45 PM   #14
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
my solution
This is how I secured a Fantastic Vent but I respect other opinions more than my own. Since self tapping screws seemed inconsistent with AS construction and rivets lack control over tightness, I chose #8 machine screws with lock nuts. Also added flat stock aluminum fore and aft to stiffen the skin. See photo.
JRF0st3r is offline   Reply With Quote
Fantastic Fan vent cover SilverEagle6 2009-2015 Flying Cloud 11 09-21-2017 07:52 AM
Rivet gun, bucking bar, fantastic fan and dome vent questions 66calstream Roof Vents, Skylights & Fans 11 03-03-2014 01:00 AM
Free Fantastic Fan Cover AtomicNo13 Roof Vents, Skylights & Fans 0 05-23-2012 12:32 PM
MaxxAir II Vent Cover over Fantastic Fan successful installation longdog Roof Vents, Skylights & Fans 2 12-02-2009 07:01 AM
Fantastic fan cover durability jordandvm 2002 - 2005 International 3 10-01-2004 06:59 PM
