Old 01-29-2010, 07:38 PM   #1
DAHarvey
2002 22' International
2004 22' International CCD
2010 25' FB Flying Cloud
Johnson City , Texas
Scratches on exterior - During Warranty Work
I took my brand new 2009 27 ft Flying Cloud in for warranty repairs and when I went to pick it up, I discovered several scratches right under the rolled-up awning. I believe the scratches occurred during work being performed on the roof. The service department informed me that they would fix them. Will this required a new clear coat finish? Or what should I expect?
daharvey is offline   Reply With Quote
Old 01-29-2010, 07:58 PM   #2
I would suggest that you contact the factory regarding that issue.
Since that clearcoat cannot be applied in the field, not even by Airstream, I have no idea what the dealer may try to do.
You may have to replace the sheet metal.
I would also suggest that you contact your insurance company, and report the damage.
Old 01-29-2010, 08:58 PM   #3
_
hi 'harvey...
no pics makes offering advice guess work.
IF the scratches are through the clearcoat, the only cosmetically perfect repair is PANEL replacement...
there is NO aftermarket "new" clearcoat available that matches the alcoa finish...
touch up will be CLEARLY visible and on a new unit, most owners have to decide what's ok and what isn't...
IF the scratches are NOT through to metal, they can be improved some...
all u need to read is right here...
http://www.airforums.com/forums/f441...low-54241.html
http://www.airforums.com/forums/f441...ari-43845.html
http://www.airforums.com/forums/f474...oat-43110.html
http://www.airforums.com/forums/f381...hes-37325.html
http://www.airforums.com/forums/f381...tch-37735.html
http://www.airforums.com/forums/f441...ize-31480.html
or DECALS can be used to cover the area...
cheers
2air'
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
warranty work marvinr General Repair Forum 13 03-24-2009 06:15 PM
Best place for Warranty Work Rugger General Repair Forum 6 01-13-2009 06:49 PM
Warranty Work Camp-Dog Commercial Listings 3 06-09-2005 09:46 PM
New Dometic...warranty work? JohnGalt48 Refrigerators 5 06-28-2004 02:29 PM
