Old 01-18-2015, 03:23 PM   #1
LOGRIDER's Avatar
2014 27' FB International
Avila Beach , California
Scratch removal
All,
We have a 2014 AS and somehow have acquired a few small scratches in the finish, nothing major, looks like "someone" may have gotten just a little too close to a bush or? I'll blame that on the co-pilot, backer-upper, executive assistant (wife).
Anyway, being new to the AS world, the simple question: Can such small scratches in the finish be removed as they would with other automotive finishes, e.g. polishing compound etc. ? If so is there some special technique that should be followed? As I understand it, when waxing the rig, only horizontal motion should be applied rather than rotary or vertical strokes.
Thanks for the advice.
Logrider
"don't let life get in the way of living"
LOGRIDER is offline   Reply With Quote
Old 01-18-2015, 08:02 PM   #2
2012 30' Classic
Homosassa , Florida
I had someone wash my trailer and while washing the roof pulled the sandy water hose across the top and scratched the surface. It could not be rubbed out so they had to replace the entire panel. I hope that your scratches are less but if they are in the aluminum I don't believe you can rub them out. If not too noticeable I would ignore them but treat them to prevent corrosion. I wish you well
Tater is offline   Reply With Quote
Old 01-19-2015, 06:25 PM   #3
LOGRIDER's Avatar
Thanks for the input. Unlike what you describe these are surface clear coat scratches, that should be easily rubbed out if that is an approved method.
Logrider
Old 01-19-2015, 07:37 PM   #4
2016 30' Classic
Erie , Colorado
Try Griot's Paint Sealer product with their random orbital polisher. That has helped me with the 'rubs' that are always attracted to the trailer. I use Paint Sealer as a general 'polish' on the AS and my cars.
I think the 'follow the grain' was for the pre clear coat panels of earlier model trailers.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 01-20-2015, 05:52 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
I also use the Griot's products.
I've found the One Step Sealer works very well on surface scratches.
The mop-on-a-stick along with their car wash will also reduce the chance of unintended scratches.
I don't think you'll find better microfiber products anywhere.
Good Luck
Old 01-20-2015, 06:49 AM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Originally Posted by ROBERT CROSS View Post
X2
Good Luck
X3^
Since Bob directed me to Griot's products my AS and cars have been glistening! Best On The Planet and I've tried lots of them over the years.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Scratch removal:-( Eric H Ribs, Skins & Rivets 15 03-24-2014 10:50 AM
Scratch Removal jehall Exterior Restoration Forum 3 01-20-2008 11:11 AM
Seek "how to" for paint scratch removal The A Team Repairing/Replacing Floor &/or Frame 1 01-12-2007 12:46 PM
Clearcoat scratch removal mcostanzo Clearcoat, Exterior Paint & Trim 3 07-01-2003 09:28 PM
Removing Scratch with 1200 Grit Paper Jim Clark Cleaning, Stripping & Polishing 4 10-13-2002 06:51 PM
