Old 08-27-2019, 08:35 PM   #1
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Scary picture
I’m posting one of my scariest Airstream photos to date.....
Dept of “OverKill”
Old 08-27-2019, 08:36 PM   #2
Portland , Oregon
Ouch!! That hurts.
The making of a new Blog post?????
Cheers,
Bryan
blacklab is offline   Reply With Quote
Old 08-27-2019, 08:50 PM   #3
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by blacklab View Post
Ouch!! That hurts.
Cheers,
Bryan
Sneak peak....
ID:	350644   Click image for larger version
Dept of “OverKill”
Old 08-27-2019, 09:35 PM   #4
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Sorry, I fainted..
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 08-27-2019, 10:19 PM   #5
Paradise , Texas
There really is nothing like drilling or cutting a hole in the side of your trailer.
What's worse, is when you finish reskinning the upper side sheet, and have to cut window holes in...
That's quite nerve racking!
Crackerman is offline   Reply With Quote
Old 08-28-2019, 05:49 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The camera was not level...right? 🤔
You are a brave soul...and careful.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 08-28-2019, 06:03 AM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yes. Well I say yes. Those are factory drilled holes. I was filling a hole through the inner skin to allow clearance for my SmartPlug install.
Smart plug mounted straight anyway.
Dept of “OverKill”
Old 08-28-2019, 06:27 AM   #8
2009 34' Panamerica
Still , in the thick of it
I hope you put a coating of clear coat or clear nail polish on the raw cut hole edges. Disturbing the skin coating, if moisture gets in there somehow, for whatever reason, you **could** see fillform corrosion lines start to appear behind the gasket and eventually to the visible body. Simply can't be too careful.
That was an unnerving picture though!
panamerican is offline   Reply With Quote
Old 08-28-2019, 06:43 AM   #9
2017 20' Flying Cloud
Georgetown , Texas
OK, how did you pilot that hole saw? I just had visions of it skating across the pristine aluminum skin when you started the hole. Maybe a wooden plug made by first boring a hole in a thick piece of wood?
SYC2Vette is offline   Reply With Quote
Old 08-28-2019, 07:07 AM   #10
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
The outside hole in the skin is factory... it was where the Furrion 30A inlet was mounted.
I simple used the same size hole saw as the factory hole and drilled through the inner skin to allow plenty of clearance for my new SmartPlug install. https://www.technorv.com/smartplug-3...t/?Click=11781
The 2 1/2” hole saw has a center pilot bit.
Dept of “OverKill”
Old 08-28-2019, 07:28 AM   #11
1981 31' Excella II
New Market , Alabama
I would coat all the exposed edges with clear coat to protect from corrosion. You can do what they call wet install on screws. Coat them with clear coat then install them.
Perry
Old 08-28-2019, 08:26 AM   #12
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Use a nail punch to create a dent in the aluminum skin, then set the center drill portion of the hole saw in that dent before you start the drill. Keep some pressure on it, and it can't skate around as it drills the hole. That's what we did when drilling pilot holes for additions and changes to our trailer as we reno'd.
We didn't have any clear coat left to worry about...
Kay
Old 08-30-2019, 09:15 PM   #13
Journeyman
2016 25' International
Deerfield , Massachusetts
There's an old trick for this: nest the hole saw that matches the existing hole inside the holesaw for the larger hole. That provides enough piloting support when you need to widen an existing hole.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 08-30-2019, 09:21 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I EMPATHIZE!!! Did that 8 years ago.. when upgrading to 50AMP... posts are here somewhere. I used closed cell foam to stiffen the outer/inner skins the day before I cut the hole.
I used HUBBELL parts and made my own shore cable. Still shiny!!!
Great job!
Peace and Blessings..
Channing
WBCCI# 30676
Real scary guy99 General Motorhome Topics 1 05-27-2006 03:05 PM
Furnace questions and scary sounds in turns amathis55 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-07-2006 05:05 PM
Scary light switch silvrtwinkie Electrical - Systems, Generators, Batteries & Solar 22 06-16-2005 05:58 PM
Scary! swebster Mechanics Corner - Engines, Transmission & More... 7 08-27-2003 10:18 AM
Scary,dark Moments ALANSD Airstream Motorhome Forums 13 07-23-2003 04:51 PM
