Old 08-30-2019, 10:38 PM   #15
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Gah!! No I feel stupid. Instead of drilling from the outside, I drilled only a pilot hole from the outside, trying to eyeball the center, then went inside to drill the big interior hole, which was a real pain to get to. This was on 23FB I had before. Why can't I see things like this more obviously.
pcskier is offline   Reply With Quote
Old 08-30-2019, 10:59 PM   #16
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Great Minds don’t always think alike......
Dept of “OverKill”
Old 08-31-2019, 12:09 AM   #17
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
I'm preparing to install a 30 amp stainless Furrion port on our 68 Caravel.
This guy is drilling through his 68 Caravel for the same reason......will help with previsualization.
https://www.instagram.com/p/BaeaPvLFjaZ/
Thanks for the tips on starting the hole.
SilverWind is offline   Reply With Quote
Old 08-31-2019, 10:36 PM   #18
Journeyman
2016 25' International
Deerfield , Massachusetts
That's good practice when you're working with wood (to drill from the show face)... not really necessary with the aluminum but probably did make the interior side of the hole cut a little cleaner.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 09-10-2019, 03:41 PM   #19
Bumpy's Avatar
2003 30' Classic
Edisto Island , South Carolina
Hole saw Brand & Outlet
Originally Posted by GMFL View Post
I’m posting one of my scariest Airstream photos to date.....
The one you used doesn't look like those I used as an electrician, a million years ago. They had numerous teeth. They tended to wobble & oversize the hole. Could yours be a diamond blade?
Asking for a "friend", of course.
Politicians, like diapers, should be changed often, and for the same reason!
Mark Twain
So 'em
Bumpy is online now   Reply With Quote
Old 09-10-2019, 04:06 PM   #20
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
I might have fainted if I'd known what I was looking at. But I did guess that it was for a smart plug so I'm learning! You guys are hilarious--thanks for the entertainment!
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 09-10-2019, 09:00 PM   #21
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Nope just a standard bi-metal Milwaukee holesaw.
Dept of “OverKill”
Old 09-11-2019, 04:56 AM   #22
Bumpy's Avatar
2003 30' Classic
Question Smart Plug Installation
👍Just ordered the complete smart plug (stainless) to install myself.
Of course I'll have to figure how to remove the carpeted "step" on the side wall. I'm guessing it's not screwed to the inside skin. Any thoughts on this?
Mark Twain
So 'em
Old 09-11-2019, 05:24 AM   #23
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
You should be able to do all the work from outside if you want to. Mine had enough slack in the wire to pull it out of the wall to work on.
Dept of “OverKill”
Old 09-11-2019, 05:47 AM   #24
Bumpy's Avatar
2003 30' Classic
My '03 Classic has the old style permanently installed cable. So I have to open up the interior side to access the junction box between the panel & terminating cable.
Oh wait, this is for a friend 😱😎
So...
Mark Twain
So 'em
Old 09-11-2019, 06:53 AM   #25
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yeeesh; that's nothing.
Try cutting a 14"x14" hole on the roof, just ahead of the end cap, (that you can't sit or step on); knowing that 120 volt and 12volt wiring are running just underneath the skin; praying that AS pre wired for a rear compartment fan, (they did).......that gets the pucker factor up!
Cheers
Sidekick Tony
Old 09-11-2019, 07:12 AM   #26
Bumpy's Avatar
2003 30' Classic
Unhappy
Sidekick Tony
I'll take this under advisement 😱🤡
Mark Twain
So 'em
Real scary guy99 General Motorhome Topics 1 05-27-2006 03:05 PM
Furnace questions and scary sounds in turns amathis55 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-07-2006 05:05 PM
Scary light switch silvrtwinkie Electrical - Systems, Generators, Batteries & Solar 22 06-16-2005 05:58 PM
Scary! swebster Mechanics Corner - Engines, Transmission & More... 7 08-27-2003 10:18 AM
Scary,dark Moments ALANSD Airstream Motorhome Forums 13 07-23-2003 04:51 PM
