Old 05-21-2014, 12:36 PM   #1
estegmann's Avatar
2012 19' Flying Cloud
San Diego , California
Sap & Water Damage
I have a new 19 ft flying cloud. On my last trip sap from trees peppered my trailer and although most of the sap was removed without any major issues or damaged the sap on the plastic window covers was not. I've tried to be careful not to damage and scratch the covers but am now in need of advice as I have began scratching. Any help here would be greatly appreciated. Also any thoughts on taking care of the scratches..
One other question, I hosed down my trailer when I returned from this last trip trying to get some of the dirt off. I didn't dry the unit on that day and now noticed the battery cover and the rear bumper cover has paint damage which resembles hard water deposits. I've tried everything to remove this and now feel that my only fix is to have these covers re-painted. I've used a mild auto soap, auto polish, white vinegar, a CLR solution and nothing has worked.
estegmann is offline   Reply With Quote
Old 05-21-2014, 10:36 PM   #2
dave_oleary's Avatar
2013 25' FB International
Gig Harbor , Washington
Ouch, I know the pain. I have a 2013 International and I cringe at any problem that arises. You could try Bug and Tar Remover. I think it's made by Turtle Wax. That should be safe for the windows. A suggestion for the scratches would be to go to an automotive paint supply store in your area. You could even take in one of the windows. They are experts in paint and automotive finishes and I have talked to them about scratches and how to buff them out. I bet they could offer you some advice on getting the scratches out and how to remove hard water spots. We have hard water and I have to be careful to wipe the water off before it dries on the AS. A good coat of wax also helps prevent this. Good luck.
dave_oleary is offline   Reply With Quote
Old 05-22-2014, 05:39 AM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
This probably will sound too simple to be true, but try using plain, really hot water on a rag to remove the tree sap. Works for me! I too went through the gammon of products before stumbling on this easy solution :-)
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-23-2014, 08:34 AM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Sap is easily removed with rubbing alcohol. Go to a motorcycle or boat shop. They will have scratch remover.
Ahab is offline   Reply With Quote
Old 05-23-2014, 09:33 AM   #5
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Citrus based bug and tar remover works great.
Old 05-23-2014, 09:47 AM   #6
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
For the windows you might want to look for a product called Novus. It is an acrylic cleaner and comes in three grades, heavy scratch remover, fine scratch remover, and plastic clean and shine. You will also need the cloth for using it. TAP Plastics is a good source.
Photobum is offline   Reply With Quote
Old 05-23-2014, 10:10 AM   #7
estegmann's Avatar
Thank you all! After using bug and tar remover with some success, I tried Meguiar's auto polish on a small section of the plastic window covers and had great success with all if the small superficial scratches. I've since polished the entire front window cover and it looks much better.
Tree sap removal?? wyhjr Cleaning, Stripping & Polishing 32 03-05-2017 11:13 AM
Pine Sap Removal from Plasticoat Gator1 Clearcoat, Exterior Paint & Trim 9 08-07-2009 10:30 AM
Doh! Pine sap leads to light scratching! TennisMan Cleaning, Stripping & Polishing 5 09-05-2008 06:34 AM
Have top half pine sap problem ernesto ca Cleaning, Stripping & Polishing 3 09-23-2006 06:00 AM
Remove Pine Sap from Zip Dee Sav'h Steve Awnings 2 08-05-2003 04:05 PM
