Old 11-06-2013, 11:48 AM   #1
Von Moritz's Avatar
1968 26' Overlander
Kitchener , Ontario
RV Restoration places in Ontario
Hello Everyone!!
I have recently purchased a 1968 Land Yacht Overlander, 26 footer. I am very much looking to restore it this winter (2013) but finding a restoration guy is very difficult so it seems. I am in Kitchener Ontario and the local "restoration RV" guys don't touch such an older trailer. I am confused because they use the word "restoration" lol
I would like to do a lot of the work my self or have someone that I can ask question to and get advice. I like helping out the little guys business as I am one my self. Anyone know of someone?
The winter is fast approaching and I am eager to get started
ID:	199454   Click image for larger version
ID:	199456   Click image for larger version
Von Moritz is offline   Reply With Quote
Old 11-06-2013, 11:57 AM   #2
Ottawa , ON
Looks like you might need new axles, but what else do you want to do?
Old 11-06-2013, 12:11 PM   #3
Von Moritz's Avatar
1968 26' Overlander
Kitchener , Ontario
Hey!
I have taken it in to a local place here and they redid all the brakes, bearings and such. I was told the axles where fine. I wanted the trailer to be safe and legal for the road. Looking to redo the entire thing, what I have seen it's called a 'shell off' it's going to need frame work and a new floor. So far, I haven't been scared away for all this work, I am looking forwards to it all
Old 11-23-2013, 02:47 PM   #4
Ottawa , ON
The thing to do is to start by reading some of the longer threads on shell-off work. Read till your eyes fall out, then go back and do it again.
Seriously, you need to get more specific in what you are doing and what problems you are seeing in order to get comments on those issues.
What you are contemplating is a huge job, and I sure hope you have an indoor heated are to do it in.
Post a lot of photos and keep us informed, OK?
Old 11-23-2013, 03:23 PM   #5
1994 30' Excella
Mississauga , Ontario
Check out Doug on the forum. He uses the handle "shackman" He is near Stratford I believe.
Al
Al and Jean
TAC ON-3
Old 11-23-2013, 03:50 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Axles
The reasons you need new axles are: 1) Your trailer is sitting too low at the wheel wells. This indicates that the torsion rods that provide a for a smooth ride have lost their ability to spring back to the up position. When this occurs it causes a rough ride with more shock being transferred to the trailer from road issues such as pot holes and imperfections. That can result in damage to the frame as well as the interior and exterior of the trailer over time. 2) It makes for a harder time changing out a tire in the event of a flat or blowout. Many times RV techs that don't have experience with these type of axles don't recognize the issue that worn axles can have on the ride of the trailer. Check the search function tab on the blue bar above and use keywords like torsion axles, rubber rods, axle replacement and the like to see posts and threads regarding what others here have experienced. You should also check the website InlandRV.com and read up on how to check for worn axles. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 11-25-2013, 09:42 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Did you contact Brian in Dorchester? You may also want to speak with Steve Garbacz at Can-Am (he used to do clear coating etc before he got into sales). Steve did some good work for me when I had a LY motor home.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-26-2013, 12:25 PM   #8
Von Moritz's Avatar
1968 26' Overlander
Kitchener , Ontario
Hey Aage!
I hear you reading all these forums, I have taken up to Youtube as well to search it for everything Airstream.
With what needs to be done, well I think its everything. I need to get to the frame to insure its good to go, or fix what needs to be fixed. I am learning that I am needing new axles (on top of the work I have completed and told they were good) and I ok with that. My main concern is to make it safe!!
So with needing to get to the frame, its all got to come apart. Total tear down. So with that, should I redesign the inside or reinstall everything back into it?
I hear you on a big job! But I have definitely been bit by the AS bug My AS is sitting indoors currently! its the first time in 27 yrs
Old 11-26-2013, 12:28 PM   #9
Von Moritz's Avatar
1968 26' Overlander
Kitchener , Ontario
Hey BigEd52!!
Thank you very much for that info. I agree with you, they need to be replaced. Wish the guy I took it to would have noticed that and changed them out instead of just all the brakes.
Von
Old 11-26-2013, 12:32 PM   #10
Von Moritz's Avatar
1968 26' Overlander
Kitchener , Ontario
Hey blkmagikca
Brian in Drochester? Is that Can-Am? I have phoned them in the past when I first purchased my AS and wanted someone to go over it. The lady I spoke with told me that don't like to work on such an older trailer.
Old 11-26-2013, 01:46 PM   #11
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Al
Hey Al, he did find me even though I try to stay hidden . Welcome to come in and check out the trailers and see how much work there can be in renovating.
Name:	Home_park overhead.jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-27-2013, 10:03 AM   #12
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by Von Moritz View Post
Hey blkmagikca
Brian in Dorchester used to work for Can-Am and went out on his won. When Steve Garbacz worked on my motorhome, he ordered stuff through Brian. My suggestion is to call Can-Am and ask to speak with Steve Garbacz. Tell him that Howard who used to have a 34-ft LY motorhome suggested that you speak with him. He can give you all kinds of info and who to call.
VE3JDZ
AIR 12148
