Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-07-2005, 12:30 PM   #1
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
RV Building Code
I have seen several comments on the forum that this or that is not in accordance with the RV Building Code. Does anyone know where I can obtain a copy of this code so that the reconstruction on my Liner can conform to the requirements. Although I may choose to vary from the code, it would be good to know the requirements.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 09-07-2005, 12:36 PM   #2
driftwood
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
Rivet Rvia
wkerfoot,
Try http://www.rvia.org/
I'm sure they can point you in the right direction.
RVIA Western Office:
Marsha McInnis
(951) 274-0696
The big Pomona show is in October.
I am sure that 49 CFR (Transportation) will be referenced.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 09-07-2005, 03:23 PM   #3
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
I hope you find some data on the standards. Cause I am not sure if there are standards.
I work in real estate I know that there were no standards for manufactured homes up until 6/1/1976. Bill I will be interested in learning what you find, cause I may change the way I restore my trailer depending on what you find.
>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 09-07-2005, 03:28 PM   #4
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Here is what I found.
.What standards do I need to use when building an RV?A.ANSI/NFPA 1192 Standard for Recreational Vehicles NFPA 70 National Electrical Code (NOT AVAILABLE THROUGH RVIA - To order from NFPA call: 1-800-344-3555 or visit http://www.nfpa.org/catalog
ANSI/RVIA 12V Standard for Low Voltage Systems on Recreational and Conversion Vehicles
A helpful but not necessary publication would be RVIA's Guide to 1192 which includes sections on all three publications listed above
Looks like the standards relate to fire safety and electrical. Everything else seems to be at the discression of the manufacturer.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 10-31-2005, 09:44 PM   #5
alfalsetto
alfalsetto's Avatar
Profile:
I didn't know that there is a RV Building Code on Motor Homes or is this a joke.
alfalsetto is offline   Reply With Quote
Old 11-01-2005, 12:14 AM   #6
wkerfoot
wkerfoot's Avatar
1954 29' Liner
Orange , California
Alfalsetto,
No, this is not a joke but a serious conversation on how to properly and safely, restore and maintain your Airstream. There is often a comment that this or that construction technique is or is not according to code. What I found out is that there is no RV building code, but rather a set of standards that manufacturers have voluntarially agreed to comply with to obtain the RVIA approval. I have also discovered that RV manufacturers are subject to the national fire code.
I happen to like codes because it tells one how to properly construct something which you may not know unless that is your business.
Bill
Old 11-01-2005, 06:12 AM   #7
markdoane
Profile:  , Minnesota
Images: 59
If we had no standards (like SAE J684), every travel trailer would have a different type of hitch.
I can't imagine trying to match a 2 1/8", class III.a coupler onto a 54mm, class 4B hitch ball.
Non-contributing deadbeat.
Old 11-01-2005, 10:34 AM   #8
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Check out the Mobile Home Manufacturer's Association for info, too.
Old 11-01-2005, 10:34 AM   #9
Action
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
I believe that has happened in the past.
And SAE sets standards not code. The RV manufactures do not have to comply with a SAE standard. And they would be silly not to.
>>>>>>>>>>>>>>>>Action
Old 11-01-2005, 01:21 PM   #10
alfalsetto
alfalsetto's Avatar
Profile:
I like to see Standards to keep the blood line on the Airstream the same. I like to keep My Airstream to looking like a Airstream! Thank's for the help.
